missing link
easy question for the turbo guys, what does a missing link do and doe u absolutly need one for a turbo setup...any explanation appreciated. thanks
Re: missing link (zexifiedlude)
it bleeds off boost before it reaches the map sensor.....if the map sees boost then it will throw a check engine code and put your car into limp mode.
Re: missing link (onemoreday21)
Like onemore said, it bleeds off the boost so your MAP doesn't see boost and throw you into limp mode.
With a chipped ECU running crome, uber, hondata, ect you don't need a missing link or check valves. |
gotchia, thanks guys
| All times are GMT -8. The time now is 11:58 PM. |
