Maybe a dumb question... Nitrous question
I'm just bored at work, tried googling it but didn't find much. Basically I was wondering...
Most people that I've seen that do dual stage nitrous usually run a single fogger for the small shot and a dpi kit for the big shot.... I was wondering, if you could basically run 2 different shots through a wet foggers (dpi set-up), doing say the small shot through the fuel side, big shot through the nitrous side. Obv this would make it a full dry kit using ecu controlled fuel. Idk bored at work, and seeing if maybe this would be doable as long as you have the fuel system to support it.
Sorry if this is a dumb question
I believe that would be sound as you have described. The very small ammount that will be injected at low levels will be a VERY small (#10-#14) jet!!! You MUST place a filter from the solenoid. They are very, very small. Do not underestimate how easy they are to clog.
Otherwise, you can do as you have suggested with the proper ECU and injectors. Though, you may have to come up with a way for the dual enrichment, it is possible. Hondata s300 only has one that I am aware of, but you may be able to with the regulator psi or something similar.
Btw how's the del sol doing? Any updates?
I would download the latest s300 specs or check out the website for dual stage activation. Last I remember reading a year ago only had one stage though.
Man, you don't know how much I want to post up some info on the build! I really hope to have some GREAT info about the head. Endyn (Larry Widmer) has promised to do a full write up on the whole project with lots of pictures, so I'm waiting to deliver as I said like 5 months back.
Sorry for the steam vent, just waiting sucks.
Hell yeah man, I can't wait to see it either.
Also went to hondata website and it says s300 has 3 outputs for nitrous control. Is this what would be needed? Or is that just for activation of nitrous not different maps?
