max piston size? bore size?
Old Jul 15, 2002 | 02:57 PM
rOby's Avatar
Default max piston size? bore size?
just sent a block to GE, what size pistons should i run...in mm. im set on runing stock compression but as far as width how far should i go.? i originally planned 84mm but i could i gain more gains at 86mm? is it safe to run that size plus boost? i want to one day bring the boost to 20lbs track ....boost on street will be 9 lbs.
thanks...its gettin mated w/ eagle rods...gimmies suggestions.
what would 86mm be , 2.1L?
Old Jul 15, 2002 | 03:22 PM
MiraiZ's Avatar
Default Re: max piston size? bore size? (roby)
we have no idea what engine you have???
Old Jul 15, 2002 | 03:26 PM
rOby's Avatar
Default Re: max piston size? bore size? (MiraiZ)
its a b18c gsr motor
sorry
Old Jul 15, 2002 | 03:45 PM
Bnjmn's Avatar
84.5mm is the biggest that GE will recommed for a boosted motor...you can go 86 on an NA engine.
Ben
Old Jul 15, 2002 | 03:47 PM
rOby's Avatar
Default Re: max piston size? bore size? (Bnjmn)
thanks for the reply ben , ur the best.
what does 84.5 equate too, 2.01 liter?
Old Jul 15, 2002 | 09:35 PM
Bnjmn's Avatar
Right around that area..1.98 or something. I don't have the specs/calculator handy.
Ben
Old Jul 15, 2002 | 10:16 PM
Flamenco-T's Avatar
IMO, stick with stock bore or a lil over stock bore...just in case you bent a rod or melt the piston, you can always bore it out a lil larger and be as good as new...
versus running 84 or 84.5 mm, you'll have to get new sleeves..but again with perfect tuning, everything can be preventable....
it's all about tuning...
luckypon7
Sep 10, 2004 08:37 AM
TheYellowDart
Mar 26, 2004 09:36 AM
eG_6ix
Nov 19, 2003 11:26 PM
