Max HP on stock axles
Old Jul 15, 2004 | 05:48 PM
riceburnah's Avatar
Default Max HP on stock axles
I have 97 LS turbo, I'm running street tires no slicks how much HP can I push at the wheels before aftermarket axles?
Old Jul 15, 2004 | 05:51 PM
B18C1CYA's Avatar
Default Re: Max HP on stock axles (ihaterice8)
the thing that brakes axles is a shock load, which is where your tires grip so good that you shear the axles off at the hub, it happend to ITR206 i think
Old Jul 15, 2004 | 06:43 PM
Tchleung's Avatar
they'll snap if you have ltosa pweor then drop the cluthc or even slightly drop ti for a hard launch then the engagement jsut breaks ****.. whena t the line.. pull the ebrake up enoguh to hold the car a tiny bit. ride the clutch while holdnig revs ready for a launch. donig this will creep teh car forward a bit and ahve everything in full contact so tehre is elss ofa shock when you let go for the launch. jsut be sure to let go of the ebrake okay?
Old Jul 17, 2004 | 10:10 PM
crazyitr's Avatar
Default Re: (Tchleung)
I broke my axles on street tires w/ 200 whp.
Get the axles or risk getting stuck somewhere.
Old Jul 18, 2004 | 12:53 AM
pngfolife's Avatar
Default Re: (crazyitr)
I wasted the differential output bearing at 10 psi on my F23. If you spin your tires a lot at higher speeds (2nd, 3rd gears) you are more prone to damage these bearings. You will probably break your axles if you use slicks or are constantly launching hard. High horsepower cars don't break axles unless they have Godly amounts of traction. Your car is definately traction limited and should never break an axle on the street unless you have 19" rims or crazy tires.
Old Jul 18, 2004 | 01:38 AM
Hawkze_2.3's Avatar
I trashed my axles twice on my H23,
prelude with I/H/E (that rhymes)
Old Jul 18, 2004 | 03:04 AM
h22 ef's Avatar
Default Re: Max HP on stock axles (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">I trashed my axles twice on my H23,
prelude with I/H/E (that rhymes)</TD></TR></TABLE>
no it doesnt
Old Jul 18, 2004 | 04:05 AM
ritalin
Guest
Posts: n/a
Default Re: Max HP on stock axles (h22 ef)
Lol. Yes it does.
Htwentythree
IHE
Notice the rhyming scheme.
Old Jul 18, 2004 | 06:50 AM
Wasted_1.6EL's Avatar
Default Re: Max HP on stock axles (ekhatch00)
Htwentythree
Eye-H-Ee
Its considered a poor rhyme in poetry, go back to the drawing boards.
Old Jul 18, 2004 | 11:13 PM
pngfolife's Avatar
Default Re: Max HP on stock axles (Wasted_1.6EL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wasted_1.6EL &raquo;</TD></TR><TR><TD CLASS="quote">Htwentythree
Eye-H-Ee
Its considered a poor rhyme in poetry, go back to the drawing boards. </TD></TR></TABLE>
Ha Ha!!
Old Jul 19, 2004 | 04:33 AM
White Smoke's Avatar
i my honda
Global Mod
It really all depends I broke my JDM itr 36mm axle's my 2nd run, my first time at the track since I bought the 99 si (came with 5 lug). Both inners were trashed. No snapping just shaking! I would say the pass. side was the worst of the 2. Any way the car had I/H/E and lowered with sportlines/koni/camber adjusters front and rear with yokohama street tires and act clutch. I was not dumping the clutch super hard core at ALL. Launched a 3K and I have experience launching at the track in all kinds of different Honda’s and it made no difference, the axle's broke!
On the other hand I have seen 400+hp Honda's using stock axle's w/o a problem and also have not had 1 problem with my other si (same year) with aprx 275hp and still running on the axles I drove it off the showroom floor with 5 years and 60k miles ago (been boosted for 6k or so)
I would say just stick with stock until it brake's. More than half the time when an axle brake's you can still drive the car any way. Just my .02$$
Old Jul 19, 2004 | 06:04 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Max HP on stock axles (si2die4)
Courtney Green (UglyassCivic on here) as well as myself have used stock axles all of last season ( i think he still is), hes gone low 10's on them, ive gone mid 10's on them... Both cars were makin 600hp or a shade under 600hp (in my case)... Stock axles, stock diff.. all driver
Old Jul 19, 2004 | 06:11 AM
PM-Performance's Avatar
Default Re: Max HP on stock axles (SIXTYdashONE)
Listen to Ron . No one seems to understand its not the HP that breaks axles. its the sudden Impact and too much traction that breaks them . if you launch higher chances are you will clear fine . On reg street tires i dont see how you can break them unless your susp is not set up correclty. and yes i have seen some stupid ricers go up to the line in stock SOHC civics with the rears jacked and the front slammed and snap axles on stock tires. putting too much weight and stress on the joints
Old Jul 19, 2004 | 06:35 AM
MachAF's Avatar
Default Re: Max HP on stock axles (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote"> stock SOHC civics with the rears jacked and the front slammed </TD></TR></TABLE>
Mexican style.
Old Jul 19, 2004 | 09:15 AM
Muckman's Avatar
Moderator in Chief
Also another note to consider - The more you are lowered the more stress will be placed on the CV Joints.
Old Jul 19, 2004 | 11:56 AM
Do you mind if i ask you what launch technique you use.I have a general idea but id like a second opinion.
Old Jul 19, 2004 | 01:10 PM
b16sedan's Avatar
Was running stock axles with my B16/60-1 combo. Still going to be running stock axles with my 84MM GSR + T67 combo
SilverWarrior
Jun 4, 2007 11:40 AM
IntegracinGSR
Jun 28, 2004 10:03 AM
FastSS
May 19, 2003 07:48 PM
IloveNewt
Apr 23, 2003 01:11 PM
HybridMT
Nov 1, 2001 09:05 AM
