max boost with 11:1 compression
What is the max boost i could run with 11:1 compression , running a 255lph fuel pump 8:1 vortech fuel press regulator 550cc injectors and a safc....
thanks
Gilbert
thanks
Gilbert
would 10psi is good? or should i start from 6psi and tune it up??
You can blow it up at 3 psi in a very lean condition.
so I better lower the compression 9:1 then, i have hear of some integras type r running high compression with boost on stock internals.. my understanding is as long as there is enough fuel and a good intercooler chances of blowing are very low.. like i mention before im not running stock fuel system , im running enough fuel to support 330hp on a 4 cylinder application..wher can I find information on this turbo type r...
thanks
Gilbert
thanks
Gilbert
94TealGSR
Jun 5, 2003 08:54 AM
