Massive amounts of boost creep d16
so how many psi do you hit with the one yellow? and I'm not a tuner however i soon will be purchasing all the stuff to start tuning. Theres no telling how much cash i've spent having different people tune my car lol its f'n rediculous
problem solved!!! put the small spring in and bam 8lbs consistantly no fluctuating or nothin. Tial products are quality, their dealers however can be full of crap. .5 bar my ***. more like 1.5 bar lol thanks for all the help guys, i'll be gettin her tuned tomorrow at 8 in da morning on 18lbs!
thanks honda-tech
thanks honda-tech
Heres a totally off topic question. What weight oil do you guys usually run during the winter months? 10w30, 5w30? I have a vitara setup and it has a slight ticking noise at light throttle, i've heard several vitara guys say its normal and mine doesnt get worse seems like if it was anything rod bearing wise it would get worse. its got about 3 or 4 thousand miles on it now and at idle it sounds perfect no knock or anything, its just at partial throttle it makes a ticking noise so i was just curious to see what type of oil u guys r running, maybe a little thicker oil will quiet it down?
vitaras make noise from pistons slap, not muchyou can do. You run whatever weight oil the bearing clearences are setup for. if its stock bearings clearence then 5w30 or 10w30
Could also be your injectors
cool, thats good to hear, i've put plenty of motors together but this is actually my first vitara build. thanks for the advice man.
Good to see you got it sorted. I've been in Manchester for the last 3 months and I'm finally gettin a chance to go home(Bham) and install the parts I've collected for my turbo D project..
Do you have a build thread? My girl will still be on the same project so I will be back and forth when I have offtime and we should getup
did adam ever tune your car? im wondering just how good he is, ive heard alot about him from people around middle tn but im really picky about who messes with my stuff. he have any experience with hondata s300? pm me, and if you ever need any help im only like 30 to 45 min away.
TurboIntegra
Aug 11, 2001 01:23 PM
