map sensor and AEM EMS
Old May 20, 2003 | 08:18 PM
R THIS's Avatar
Default map sensor and AEM EMS
will i need to get a 3 bar map sensor to run 12 lbs with the AEM EMS, or will the stock map sensor work? thanks for any help!
Old May 20, 2003 | 08:27 PM
metal-x's Avatar
Default Re: map sensor and AEM EMS (R THIS)
I wanna know also
Old May 20, 2003 | 08:46 PM
turbo craig's Avatar
Default Re: map sensor and AEM EMS (metal-x)
stock is good to abt 11 lbs 3 bar is good to 28
Old May 20, 2003 | 08:47 PM
Tinker219's Avatar
some have run 10, some have run 12 just fine. depends on the construction of the individual map sensor, but usually 11psi is the swith-over point...
Old May 30, 2003 | 05:52 PM
Neukin's Avatar
Default Re: map sensor and AEM EMS (Tinker219)
try it at 12 or whaterver and if it doesnt work go for the 3bar GM or aem. you have to go to the aem website forums and get the new data entered in to the table so you can use it. go to the site and do a search for the map sensor junk and you'll get all the info you need.
Old May 30, 2003 | 06:03 PM
TKERacer619's Avatar
Default Re: map sensor and AEM EMS (toyosupr)
You say the GM 3 bar map sensor ????? I used to use the ERL-FM2.... I believe it came with a GM map sensor. It has a 3 wire plug.
Is this the same 3 bar you guys are talking about?????
Modified by TKERacer619 at 3:42 AM 5/31/2003
Old May 30, 2003 | 06:09 PM
niedejb's Avatar
Default Re: map sensor and AEM EMS (TKERacer619)
You can run 12 psi but youll be at the max range of the stock sensor. I'd go 3bar just for safety sake (its realatively inexpensive).
Old May 30, 2003 | 06:59 PM
falcongsr's Avatar
What is this crap?
Default Re: map sensor and AEM EMS (niedejb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by niedejb &raquo;</TD></TR><TR><TD CLASS="quote">You can run 12 psi but youll be at the max range of the stock sensor. I'd go 3bar just for safety sake (its realatively inexpensive).
Old May 30, 2003 | 07:16 PM
Mase's Avatar
Default Re: map sensor and AEM EMS (falconGSR)
the stock sensor wont read 12 psi.....i think its like 11.43 psi or for my car anyways.....
Old May 30, 2003 | 09:24 PM
Neukin's Avatar
Default Re: map sensor and AEM EMS (Mase)
they all have three wires, ground, power, and sender, so im thinking if its a GM 3bar sensor then is the one that reads 38psi im guess since its called a 3 BAR map sensor
Old May 30, 2003 | 09:49 PM
falcongsr's Avatar
What is this crap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">the stock sensor wont read 12 psi.....i think its like 11.43 psi or for my car anyways.....</TD></TR></TABLE>
11.43...12...11...whatever. i wouldnt push the stock map sensor past 10 psi. ...intentionally
Old May 31, 2003 | 04:45 AM
R THIS's Avatar
so im gonna need a 3 bar
do any of you guys know the GM part number for the 3 bar? i cant find it
thanx
Old May 31, 2003 | 05:51 AM
Tinker219's Avatar
search, i looked, found a post by ArTurbo, and bought one through that info the other day. Cost me $82.50 w/pigtail and shipping.
Old May 31, 2003 | 07:27 AM
Neukin's Avatar
part number for the sensor is GM 12223861 (90$) and the connector for it is GM 15305891(20$) but you can get that connector from some other GM car at a junk yard iv seen that same connector on a rx7 O2 plug so just look and you'll find
Old May 31, 2003 | 10:25 AM
R THIS's Avatar
thanks
Old May 31, 2003 | 10:44 AM
Anyone know if the ERL system comes with a 3 BAR GM map sensor?????
Old Jun 27, 2003 | 09:41 AM
b16 matt's Avatar
any map sensor off of any 89 firebird or Trans am will work
JayDMJ
Engine Management and Tuning
Sep 9, 2017 12:24 PM
ORcivicsi
Jul 12, 2005 01:48 PM
burbel
May 6, 2004 01:22 PM
int3gra
Jul 4, 2003 11:49 AM
fast[R]
Jul 18, 2002 03:00 PM
