Manifold for evo turbo?
Old Mar 30, 2007 | 09:58 PM
Sketch_hs's Avatar
Default Manifold for evo turbo?
Anyone make a CAST manifold for b series so i can use my evos stock turbo on b16?
Old Mar 31, 2007 | 01:26 PM
Sketch_hs's Avatar
bump
Old Mar 31, 2007 | 04:26 PM
urbansi's Avatar
Default Re: (Sketch_hs)
Thats a good question, the thing that you need to consider is that that turbo is a twon scroll turbo, and i havent seen and manifolds with a t-25/t-28 flange that is ment for that turbo and flanged for a b-series manifold. You might need to shell out the cash for something custom thats not cast.
Is there any particular reason you want to go with a cast manifold?
Old Apr 2, 2007 | 12:09 PM
Sketch_hs's Avatar
Default Re: (urbansi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">Thats a good question, the thing that you need to consider is that that turbo is a twon scroll turbo, and i havent seen and manifolds with a t-25/t-28 flange that is ment for that turbo and flanged for a b-series manifold. You might need to shell out the cash for something custom thats not cast.
Is there any particular reason you want to go with a cast manifold?</TD></TR></TABLE>
because cast doesn't crack like most tubular and is just so much nicer
Old Apr 2, 2007 | 12:10 PM
Sketch_hs's Avatar
im thinking about that i might have to make an adapter from like t3 to the evo turbo
Old Apr 9, 2007 | 10:56 PM
nitrohuffer127's Avatar
I build them...This particular one is for a 2g eclipse but I have also made b and d series ones....
Old Apr 9, 2007 | 11:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs &raquo;</TD></TR><TR><TD CLASS="quote">because cast doesn't crack like most tubular and is just so much nicer</TD></TR></TABLE>
Hmmm.....only cheap tubular mani's like ss auto crack, as do some cast, also with a good tubular you get a merge collector and much better flow, quicker spool and more hp .Heavy wall stainless won't crack JM2C.
Old Apr 10, 2007 | 02:38 AM
the-anti-crack's Avatar
Default Re: (nitrohuffer127)
nice looking manifold. i know a guy in eugene that makes one for the 2g eclipse that looks just like that. in fact he made a b series manifold for my 2nd gen integra. maybe you know him. (eidt.......never mind you are him) i thought i had seen that work before.
sorry for the thread jack. i would definetly take nitrohuffers127s advice.
Modified by the-anti-crack at 1:08 PM 4/16/2007
Jon7
Aug 6, 2001 11:55 AM
