Making a plastic electric turbo actually work.
Old Jul 17, 2011 | 06:25 AM
thenext's Avatar
20% cooler
Default Making a plastic electric turbo actually work.
Those "electric turbo boost super chargers +50hp and +60ft/lbs" on ebay, we have all seen them right? My friend had one of these sitting around and I use it currently to hold my air filter cone to my intake tube. It wasn't until recently that I even actually wired it up. I tried using it in just about every possible fashion but I never see my vacuum go above 0. I didn't really expect much.. I was just sort of curious if I could modify it to even get any boost out of it at all just as an experiment. It runs off 12v and I was almost thinking if I ran it on 24v it would spin faster? I don't have any hopes of this thing performing anywhere near real forced induction. I like to tinker around with silly frivolous things such as this just to prove a point to myself. How would you go about getting 1 lb of boost out of a blower motor?
Old Jul 17, 2011 | 06:46 AM
boostedb20z's Avatar
Default Re: Making a plastic electric turbo actually work.
It wont happen
Old Jul 17, 2011 | 07:24 AM
thenext's Avatar
20% cooler
It's people like you who inspire me to do things like this.
Old Jul 17, 2011 | 08:03 AM
h22-eg-hatch's Avatar
Drop the plastic turbo
Buy the reAl deal.... Lol
Those things are usually made to flow cold air to the intake
Not to boost
Old Jul 17, 2011 | 11:46 AM
SovXietday's Avatar
Consider this.
A real turbocharger spins at 100,000rpms +.
Those plastic ones, max 25,000.
Also, blowing air and compressing air are two very different things. Fin design and makeup are very important to do this.
Noble intentions, but a total waste of time.
Old Jul 17, 2011 | 11:54 AM
NA James's Avatar
Make your own with a mamba monster 8th scale electric rc motor and use a 6cell lipo battery to power it on a momentary switch. That should blow a good amount of air in. im pretty sure you can get 100,000 rpm out of it.
Old Jul 17, 2011 | 12:34 PM
th3pwn3r's Avatar
That's funny. The first idea that popped into my mind was to use a brushless motor.
Old Jul 17, 2011 | 02:05 PM
NA James's Avatar
It could work. And if it could be put on a gear/trans from like a losi 8ight-e it could spin at different speeds and a propeller from something like a turbo.
Old Jul 17, 2011 | 02:54 PM
met's Avatar
met
I would wonder how much current you would need to make any good amount of boost.
Check this link out I just glanced over it looks like 3 starter motors turning a supercharger.
http://www.turbomagazine.com/tech/04...ger/index.html
Old Jul 17, 2011 | 07:49 PM
vwbased's Avatar
have a nice day
Old Jul 17, 2011 | 08:03 PM
wunfstgsr's Avatar
Loved
Community Favorite
thats funny the idea once crossed my mind a long time ago lol
Old Jul 17, 2011 | 08:50 PM
ryguy2588's Avatar
Try a leaf blower lol
Old Jul 17, 2011 | 09:15 PM
BetterBtuning's Avatar
MAKE SURE THE LEAF BLOWER DOSNT HAVE STUFF CLOGGED IN IT OTHERWISE YOU HAVE TO RIP APART THE MOTOR AFTER SAID "AWESOME" IDEA CAUSES IT TO DROP A CYLINDER !!!!!!!!!!
SINCERELY
The Dumb *** Who Tried It
Old Jul 17, 2011 | 09:37 PM
ryguy2588's Avatar
Haha that's awesome
Old Jul 17, 2011 | 11:04 PM
rich7777's Avatar
Why don't you just wire up a hair dryer to the battery and use that ?
Old Jul 18, 2011 | 12:34 PM
Organization's Avatar
lol i was thinking along the same lines
two brushless motors turning a real turbocharger impeller thru a gearbox to either reduce or increase rpms (final drive) and power them using two motor speed controllers which you can use to controller the rpms boost ect
this is just wild thinking
Old Jul 18, 2011 | 01:09 PM
phunhaus's Avatar
Rotrex?
Old Jul 18, 2011 | 01:17 PM
NA James's Avatar
Traxxas uses a 2 engine setup and turbos spin easier then the 3 differentials on a rc truck. Hook a spur gear up to the exhaust side and spin it to 100,000+ rpm with some 6cell lipo batteries and see if it works. Should be to custom
Old Jul 18, 2011 | 02:37 PM
Sleepy.Bear's Avatar
Originally Posted by vwbased
An efficient turbo compressor providing 33 lbs/min flow (good for 300 hp) at 19 psi outlet pressure requires about 41 hp to turn it.
Eye opening isn't it?
This ^^
Why is this thread still open?
Old Jul 18, 2011 | 04:24 PM
dglassmyer's Avatar
I've considered this as well.
It seems to be a fairly logical idea to consider if you look at the path centrifugal superchargers follow.
Obviously a centrifugal supercharger operates a compressor wheel on the same principle as a turbo charger, however has a different means of propulsion.
Where as a supercharger uses a belt drive, and gear reduction system driven by an engine to make boost, why couldn't a powerful DC motor turn over a supercharger pulley like an engine could.
What I have thought as a possible option would be for the given electric motor to always spin at a set rpm.
Consider a AC motor from your typical air compressor.
They spin at 3450 rpms.
Adjusting that speed effectively to accommodate for throttle position, load and adjust the boost being delivered seems just too complicated to me.
Why not plumb in a "wastegate" downstream connected to manifold vacuum to either bleed off (at closed throttle) or deliver full boost (under load)
Just my two cents, and I doubt anything on ebay is anywhere near being a useful investment, but I credit the next for being brave and bringing up some new discussion.
Old Jul 18, 2011 | 04:38 PM
Natural Aspirations's Avatar
It takes 30,574 watts (2548 Amps @ 12v) to produce 41hp!!!
Old Jul 18, 2011 | 05:00 PM
dglassmyer's Avatar
I would like to see empirical evidence that converts thermal expansion required to power a turbocharger into a 41 hp figure.
Old Jul 18, 2011 | 05:13 PM
i built a junk yard turbo kit for like 400 bucks, lipo batteries and rc motors sounds like it would cost more than that ... but that would be a first, and if it worked you would deff have my respect
Old Jul 18, 2011 | 05:18 PM
you could use the car's electrical system for the power source instead of adding extra batteries, and you could even add a cap to limit the shock to the battery during initial start up along with the electric motor speed controllers
you get the ideal those rc motors are powerful but i think theres some better brushless motors out there with more grunt
93supercoupe's Avatar
i was seriously about to post the same thing
throw a couple lipos at it, and let it eat. HAHAHA
