Main Cap Crank Bolts
Old Jan 6, 2003 | 06:52 PM
crxhybrid1320's Avatar
Default Main Cap Crank Bolts
Does ARP make crankshaft MAIN bolts or
do you just use the OEM bolts for the Main caps for the crank.
Im using the OEM ones but am not boosting yet!
Old Jan 6, 2003 | 07:34 PM
Default Re: Main Cap Crank Bolts (crxhybrid1320)
bump
Old Jan 6, 2003 | 07:36 PM
TurboTegB18c's Avatar
THe oem main cap bolts should be plenty to handle what ur planning on throwing at it. Just make sure u torque them properly. Paul
Old Jan 6, 2003 | 07:43 PM
Default Re: Main Cap Crank Bolts (TurboD16Z6)
How much boost can these oem bolts hold up to without streching.
Planning to run boost in the future
Old Jan 6, 2003 | 07:48 PM
If you really think about it, the main cap bolts are just holding the crank in place and much stress isn't in this area. The combustion chamber is where the high cylinder pressures are at and hence the need for arp headstuds. I don't know of anyone that runs the arp main caps bolts (if they even make it) but i would think only the pros would use them. Like i said, i really see no need for them. Paul
Old Jan 6, 2003 | 07:52 PM
Thats why i asked because ive heard of someone talking about them when i rebuilt my motor but have not heard anything about them if they make them.Thanks
Old Jan 6, 2003 | 08:50 PM
earl's Avatar
Honda did a great job in their design of the main bearing webing but you are kind of minimizing the abuse they take. When a motor detonates it actually can lift the main bearing cap away from the block. With a spinning mass at 10,000 rpms, the centrifical force is tremendous. That's why the gsr block was made with a girdle. It seems the mains are good for 1000hp but at some point the weak point will be found.
Old Jan 6, 2003 | 08:58 PM
Default Re: Main Cap Crank Bolts (earl)
Thanks for the info earl , I was basing my answer on theory as i haven't seen many people have to upgrade main cap bolts. Paul
BHO
Sep 6, 2012 11:32 AM
85mm LS VTEC
May 19, 2004 07:57 PM
riceball777
Nov 12, 2003 11:26 AM
paulzy
Mar 7, 2002 12:47 PM
