ls vtec or ls turbo
Old Jul 6, 2011 | 01:24 PM
beastinisgr8's Avatar
Default ls vtec or ls turbo
So I'm stuck, I can either do an ls vtec swap or turbo my ls and Save money to build a block while running low boost.
righ now I would be fine with anything over 200hp not looking for huge numbers just something fun. As a college student money is scarce so opinions and suggestions welcomed!
Old Jul 6, 2011 | 03:30 PM
EsotericImage's Avatar
Retired Moderator
Default Re: ls vtec or ls turbo
boost the LS and build a block on the side gets my vote.
Old Jul 6, 2011 | 03:35 PM
1FASTHF's Avatar
X2
Old Jul 6, 2011 | 04:12 PM
Recommend e85 or just gas tune?
Old Jul 6, 2011 | 04:24 PM
Mr. EG's Avatar
Regular fuel will be just fine on low boost.
Old Jul 6, 2011 | 08:10 PM
sc34dc4's Avatar
If your LS is healthy then just boost it. It's an easy task to make 250+ on a simple t3/t04e 57 trim turbo and a log manifold. I ran mine for a year making 260whp beating the snot out of it until I was able to finish my built gsr.
make sure you do ARP head studs if boosting the LS.
Old Jul 6, 2011 | 08:25 PM
civickiller's Avatar
X3
Old Jul 6, 2011 | 08:32 PM
Metaphysical's Avatar
Originally Posted by civickiller
X3
x4, its what i'm going to do also, more than likely
Old Jul 6, 2011 | 08:43 PM
turbohatch96y7's Avatar
I say if you could go v tec now then I would youll make more power on less boost and run into less problems if its all done right.
Old Jul 6, 2011 | 08:53 PM
Ahh well I just replaced head gasket but used OEM head bolts will they not hold up?
Old Jul 7, 2011 | 06:59 AM
k20a2delslo's Avatar
boost the ls and build on the side. Get to save money on fuel. Only have the power when you need it.
Old Jul 7, 2011 | 07:28 AM
kyden's Avatar
what are you talking about? either way he's gonna have to run premium.
Old Jul 7, 2011 | 07:35 AM
May do e85 idk I only drive to college. Also 91 octane is the highest around besides special stores.
Old Jul 7, 2011 | 12:00 PM
hoffmanb16's Avatar
Your asking in a FORCED INDUCTION forum if you should go n/a or boost.....
hmmmm guess what answer your going to receive?
Ask this same question is the all motor section and you would get the opposite reaction.
Either way a boosted LS is the cheapest power you can get and a great option.
Old Jul 7, 2011 | 01:31 PM
lsturbo33's Avatar
My ls 57 trim 300whp has been fine for 2.5 years. Only upgrade to the motor is arp headstuds. Reasonable cheap and fun setup. I daily drive it with no problems.
Old Jul 7, 2011 | 02:14 PM
i used 89 octane on my lsvtec without detenation but i only made 266whp
00IntegraLSO-town
Feb 13, 2006 04:52 PM
95se4dr
Sep 22, 2004 11:27 PM
mvbadboy
May 6, 2003 07:30 AM
JDM DC2
Aug 8, 2002 05:26 AM
