LS Vtec head gasket???????
Old Nov 15, 2009 | 11:15 AM
88.REX's Avatar
Default LS Vtec head gasket???????
ive heard that the ls vtec head gasket is thicker than the ls head gasket and if you put the vtec one on the regular ls it will lower compression a little bit lol is this true???......lol
Old Nov 15, 2009 | 11:18 AM
93egSLEEPER's Avatar
Default Re: LS Vtec head gasket???????
there is no "LSvtec" head gasket. there is the LS head gasket, and B series Vtec head gasket. They are all 3 layer and i beleive the same thickness. dont hold me to that but i dont forsee anything making them drastically different.
Old Nov 15, 2009 | 11:20 AM
88.REX's Avatar
thats what i was thinking but i wasnt sure thanks
Old Nov 15, 2009 | 12:29 PM
EARLdaSQUIRREL's Avatar
official honda whore
the difference is the dowel pins, just get the Golden Eagle headgasket made for ls vtecs
Old Nov 15, 2009 | 06:11 PM
88.REX's Avatar
are they thicker or something? and they would fit on a regular ls right?
Old Nov 15, 2009 | 06:21 PM
what are you talking about? what motor do you need a headgasket for?
Old Nov 15, 2009 | 06:28 PM
88.REX's Avatar
B18A1 lol sorry for all the stupid questions
Old Nov 16, 2009 | 04:34 AM
Silva Bullit DC4's Avatar
If you are doing an ls/vtec setup, contact Golden Eagle. Their ls/vtec conversion kit includes an OEM LS head gasket (B18A1/B1) with revised dowel pin holes for the vtec head, and they offer different size gasket cylinder bore sizes for your particular application.
Old Nov 16, 2009 | 11:50 AM
CerealKiller's Avatar
They're both the same thickness.
Old Nov 16, 2009 | 12:40 PM
Bond's Avatar
No they do not. They use a Vtec headgasket. Check it out:
http://www.goldeneaglemfg.com/includ...yGEMgasket.jpg
Old Nov 16, 2009 | 10:19 PM
I apologize for the misinformation. I've seen conversions done with the LS head gasket, and assumed G.E. sold their kit with them.
Old Nov 17, 2009 | 08:41 AM
Bond's Avatar
no need to apologize dude. just wanted to make sure we didn't misinform anyone. You can do it with the LS headgasket, but GE explains in good detail why they select the vtec HG. Either way a great link to some good info. A good read for anyone doing LS/Vtec's
Old Nov 17, 2009 | 08:46 AM
per4mance's Avatar
Back when LS/VTECS first got big, it was stated to use the LS headgasket. Thats what I used to run 10 years ago on them. Now they say use the VTEC for cooling purposes. Its safe to use both and you can use and LS timing belt and water pump if you want. I have ran them both ways and never had a problem and they were boosted also. Also use the water pump that matches the timing belt
nightshift_rolla
Oct 1, 2008 06:44 PM
civicswap
Jun 4, 2005 06:44 PM
kerby116
Apr 5, 2004 04:29 PM
type autox
Oct 27, 2001 03:42 PM
