ls vtec build/help
Old Oct 19, 2009 | 09:22 AM
fv8s's Avatar
Default ls vtec build/help
i am sure there is info out there about ls vtec builds but i can not find a good thread and needed some suggestions and help. i have a b18b1 head and block out of a 95 teg ls that is rebuilt- a d16y8 complete block and head and i am extremely tempted to buy a b18c head to make the b1 an ls/ vtec. i am planning to run a garrett to4e turbo in either a 92-95 hatch or civic 4 door. what engine should i build and use... im not worried about money at this point just honest suggestions.. if i do make an lsvtec what parts do i need? i know wiring harness vtec soleniod. and oil pump.. but what about dizzy?
Old Oct 19, 2009 | 09:27 AM
boostedEF91's Avatar
Default Re: ls vtec build/help
building the ls vtec would be the better build.. you need a complete vtec head. dizzy and all. you have to do a lil more reading and look some more things up before you go building. google it and see what you find.
Old Oct 19, 2009 | 09:28 AM
you can buy the golden eagle ls vtec conversion kit to make your build a lil easier seeing that you arent sure how to.
Old Oct 19, 2009 | 09:29 AM
boosted k20's Avatar
use ur stock harness
Old Oct 19, 2009 | 09:43 AM
MHDesigns's Avatar
Make sure you pull the block apart and replace your bearings if you go vtec.
JDMhon
Dec 12, 2006 10:27 PM
KustomCrx
Oct 24, 2004 12:09 PM
shinji666
Aug 20, 2004 12:22 AM
bowlofnoodle
Apr 28, 2004 09:11 AM
96integra20
Feb 19, 2003 06:34 PM
