LS bottom+ R Head...??
Old Apr 21, 2005 | 11:23 PM
digital sol's Avatar
Default LS bottom+ R Head...??
Any-1 ever run a semi built LS bottom end and a Type R head? The R head is good for 450+hp as is, so wouldnt a semi built ls bottom like mentioned below make for a pretty good set-up? With boost of course
ls bottom
JE 9.2:1 Forged pistons
JE Piston rings
Eagle ESP Rods
98 jdm itr head, stock internals
would the itr head bump the compression up a bit?
Old Apr 21, 2005 | 11:31 PM
Calvinator's Avatar
Default Re: LS bottom+ R Head...?? (digital sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digital sol &raquo;</TD></TR><TR><TD CLASS="quote">Any-1 ever run a semi built LS bottom end and a Type R head? The R head is good for 450+hp as is, so wouldnt a semi built ls bottom like mentioned below make for a pretty good set-up? With boost of course
ls bottom
JE Piston rings
Eagle ESP Rods
That setup is basically the same as doing an LS vtec setup, search it up on this board. The b18c5 head is basically a b16 head with some port work, stronger valvetrain, and more agressive cams.
BTW: what do you mean by the head is good for 450+ hp as is?
Old Apr 21, 2005 | 11:37 PM
Default Re: LS bottom+ R Head...?? (xtremeazian)
thanks for info
i mean the type r head can flow 450hp the way it comes in stock form, was a guy making around 450whp running stock type r head
Old Apr 22, 2005 | 03:50 AM
mrDFWmechanic's Avatar
i wouldn't bother spending that much money on an itr i'd rather just go with a gsr or si and use the money left over on other things
Old Apr 22, 2005 | 09:01 AM
Default Re: (iROCKtheSOHC)
thats what ive been thinking about, i already have a 98 jdm itr swap, i was thinking of selling the bottom end and usuing that money to buy a built bottom end from some-1 on this board, most of the built b series bottoms on the board sell around 2000, id be swapping my high compression R bottom for a low compression semi-built b series bottom
Old Apr 22, 2005 | 09:26 AM
beerbongskickass's Avatar
Default Re: (digital sol)
You have a complete Type R engine? Dude, just lower the compression a bit and turbo that. Then build it up later down the road if you want. That Type R bottom end would be better than an LS bottom end.
B18c1/5 are the best all around motors honda ever made imo...
Old Apr 22, 2005 | 09:32 AM
Default Re: (beerbongskickass)
yea, its complete swap, 11:1
yea, i think im just gonna lower the compression with a thicker headgasket, have it tuned for 280-300whp high boost, drive it on low for daily driving and just enjoy it until it needs a rebuild, then ill go over my other options
thanks in info guys
J_M_B
31
Jul 22, 2007 02:49 PM
lscoupe
Feb 18, 2005 04:24 AM
BoostedsiR
Mar 3, 2004 04:58 AM
Mr.DC2TurBo
Oct 29, 2003 05:57 AM
