location of oil pressure source
Old Aug 28, 2002 | 02:23 PM
avividmemory's Avatar
Default location of oil pressure source
does anyone know the exact location of where to plumb for oil, on the back of a b18b block...im installing a turbo...i found the oil sensor with the plug, its next to the filter, but where do you put the "t" where does it screw into
do i need to take my intake manifold off to do it?
if anyone has a picture of what it looks like, or can tell me the exactly where to do it, id be very greatful
Old Aug 28, 2002 | 02:35 PM
98civicEX's Avatar
Default Re: location of oil pressure source (NoPowerAllRice)
the tee goes into the block where the sensor is. ummm let me look for a pic
Old Aug 28, 2002 | 02:39 PM
Default Re: location of oil pressure source (98civicEX)
this is a pic i found of a b16 block...
but it shows the tee going into a different spot, and the sensor above the oil filter...and i know the location is different from the b18b because its next to the filter on my car...
Old Aug 28, 2002 | 03:26 PM
00civicvtec's Avatar
That looks like the knock sensor above the oil filter, the T is in the right spot...but it's better to put the T on the firewall and run a line down to the block so it doesn't break off...too many horror stories...
Old Aug 28, 2002 | 04:06 PM
Default Re: location of oil pressure source (00civicvtec)
so should i just hang it, or actually bolt it to the firewall...or even tie it another hose
Old Aug 28, 2002 | 08:09 PM
Run a line (nylon or ss braided) from the oil pressure sending unit hole on the block (it is a 1/8" BSP fitting, you have to get a converter to convert it to 1/8" NPT) to a Tee on the firewall (mount it well), the idea is to not get vibration on the mounting point on the block or you will experience broken connectors and leaking oil.
I'm sure someone has got a pic.
Old Aug 28, 2002 | 11:51 PM
BoOsTeD_eK's Avatar
you should look at this...more of a constant source of presure.
I think someone on this board is selling them for under $20.
its from z10
Shadly
Aug 2, 2011 06:53 PM
Jay0016
Jan 9, 2011 11:56 AM
949
Feb 4, 2007 04:35 PM
I got a honda
Oct 15, 2005 09:40 PM
civicracer1993
Aug 13, 2004 07:55 AM
