Is a little bit of exhaust moisture normal?
Old Feb 12, 2004 | 11:29 AM
5thgencivic's Avatar
Default Is a little bit of exhaust moisture normal?
I'm pulling my wastegate off to change the spring and noticed some moisture on the "plunger" and around the flange. None is inside the manifold, just around the edge. Is it just moisture from heating and cooling? I also noticed a bit coming out of the exhaust when the car was on the dyno. I'm assuming it's normal, but I worry about little crap Coolant has stayed at the same level and same color(bright green, no residue) since day one. Oil is good. Coolant is good. Compression is good. Pic is below. thanks.
Old Feb 12, 2004 | 11:30 AM
yellowturbo's Avatar
yep it is normal, this is just some condensation... when I start my car there is always some water who exit by the tip .... if im wrong correct me...
Old Feb 12, 2004 | 12:32 PM
Default Re: (yellowturbo)
ok, cool.
3" exhaust, straight through muffler and no cat probably contribute to the moisture seen coming out the exhaust as well. I worry too much, haha. Thanks.
URA91hatch
Jun 21, 2004 08:56 PM
hybridsol
Oct 25, 2003 01:28 AM
Gen5lude
Apr 7, 2003 03:04 AM
integrx
Sep 12, 2002 09:47 PM
bananacruzier
Apr 2, 2002 10:27 AM
