In line "solid state resistors" insted of a resistor box?
Old Oct 10, 2009 | 09:11 PM
kreatekustomz's Avatar
Default In line "solid state resistors" insted of a resistor box?
I was just wondering if it is possible to use inline DC solid state resistors insted of the huge resistor box found in DSMs? I dont know how accurate the DSM resistor boxes are but I do know I can locate +/-5% resistors. I also dont know what Ohm each resistor is in the box?
Also while on the topic has anyone ran the 2.3 Ohm MSD injectors with a resistor box in a honda?
Old Oct 10, 2009 | 09:22 PM
locash's Avatar
Default Re: In line "solid state resistors" insted of a resistor box?
If you want to do it right, get a injector driver or the correct injectors.
Old Oct 10, 2009 | 09:41 PM
NonovUrbizniz's Avatar
Loved
people do inline resitors... if you search for it you'll find it...
*EDIT*
but above poster is correct.
Old Oct 11, 2009 | 05:42 AM
ls_on_boost's Avatar
i have inline resistors i soldered them into the wires 3 years with no problems
Old Oct 11, 2009 | 06:15 AM
well I could get the "right resistors" but I already have MSD 97lb 2.2 Ohms resistors...
ls_on_boost - what resistors did you go with?
Old Oct 11, 2009 | 07:07 AM
HiProfile's Avatar
The problem is you'll never really get away from the size, since they're required to disapate a little over 10 watts each. Wire-wound resistors can't be much smaller than the bricks most places sell, and there really isn't any other design that can dissapate that heat in a smaller package.
Your only option is to run the wires & resistor box under a fender or something.
Old Oct 11, 2009 | 07:16 AM
i believe they are 11ohms
Old Oct 11, 2009 | 08:06 AM
Loved
incase you decide to make things easy I have a honda resistor box with the harness and pigtails in my for sale thread in my sig.
Good Luck!
birz
Jun 21, 2006 05:02 PM
