Less power after ramhorn?
Old Feb 8, 2009 | 08:08 PM
175Shot4Door's Avatar
Default Less power after ramhorn?
Ok guys so i have a 95 ls integra thats boosted i had a ebay set up with a log manifold on 9 psi and it spun veryyyy hard 2 gear and shifting into 3rd.
I upgraded from the log mani to a nukin ramhorn manifold and from a bent up 2 1/2 inch downpipe to a nice 3 inch downpipe. Now the car is on 8 psi on a tial wastegate compared to 9psi it was on the ebay set up. Car feels slower to me not much spinning anymore? Any idea what could be causing this?
Old Feb 8, 2009 | 08:31 PM
cockerkid008's Avatar
Default Re: Less power after ramhorn?
Did you get the car re-tuned?
Old Feb 8, 2009 | 08:37 PM
GT35R_EF's Avatar
Make mine whatever you want
I'm guessing since you have no power comparisons that it hasn't been tuned since you changed over? That would be something to look at. The log manifold is going to give a little more response early anyways, but you should definitely be making more power overall with your new setup.
Old Feb 8, 2009 | 08:42 PM
No i havent gotten it retuned its never been tuned just a basemap. Dyno tunning comming very soon. The car is also VERY quiet now compared to what it used to be. i just dont understand why it would feel a little slower
Old Feb 8, 2009 | 08:46 PM
SovXietday's Avatar
Just a basemap and you're asking us what your problem is?
$50 says it's lean as hell.
Old Feb 8, 2009 | 08:56 PM
i understand that but i dident think a ramhorn and a new downpipe would make it that much leaner
Old Feb 8, 2009 | 09:00 PM
nytosc's Avatar
From: New York in the summer, South Carolina in the winter
Well first of all your on less PSI, secondly you just changed the whole VE of the motor, Thirdly your on a basemap.
All these "basemaps" you see online for sale, are pretty much people who have no clue whats going on and they just burn a similar tune to a chip and make profit.
I would only trust a basemap to get me to a tuner, and it would have to be from someone good like phearable ect.
Old Feb 8, 2009 | 09:11 PM
96 GSR-T's Avatar
lol x2
OP by your first post it seems like you are trying to somewhat suggest EGAY is better than a well built ramhorn, please stop
So you never got it tuned in the first place with the egay kit? Then you changed your setup still on the origional map that is just meant to drive your car to a dyno to get tuned and created a thread about it not being a tire burner like it was before?
Old Feb 8, 2009 | 09:15 PM
MikeySpec's Avatar
So you think i shouldnt go ramhorn instead of a log mani? Does vtec hit hard with the ramhorn? Like crazy hard?
Old Feb 8, 2009 | 09:18 PM
96 GSR-T's Avatar
Is this a joke?
If you can feel some crazy warp drive VTEC engagement then your car isnt tuned right, VTEC should be a smooth transition in power.......
Old Feb 8, 2009 | 09:19 PM
Originally Posted by 96 GSR-T
lol x2
Not saying that at all or i wouldent have spent $600 on the manifold...
Old Feb 8, 2009 | 09:21 PM
96 GSR-T's Avatar
get the car tuned by someone reputable, do you have a wideband on the car?
Old Feb 8, 2009 | 09:22 PM
The motor is a LS with a b16 tranny it used to be automatic i hear the automatic cams are different ? Anyone know anything about this?
Old Feb 8, 2009 | 09:29 PM
tegman23's Avatar
Not to bash but you just said you spent $600 on just the manifold. So you thought a $600 turbo kit, would flow close to what a $600 manifold and much bigger down pipe would..Get the car tuned your new setup is probley way lean...
Old Feb 8, 2009 | 09:36 PM
Jockobo's Avatar
maybe your rings lands are toast already from the basemap
Old Feb 8, 2009 | 09:38 PM
96 GSR-T's Avatar
I was thinking this, and then it went even leaner with the ramhorm 3" combo.....
Old Feb 8, 2009 | 09:45 PM
i dont think so. Comp is 180 178 179 176. Ive only got into it twice with the new set up. Im sure it just needs to be tuned. In 2 weeks it will see the dyno. Hoping for around 300 on 12 to 14 pounds
Old Feb 8, 2009 | 09:58 PM
Chicas's Avatar
well you are on the right direction in getting it dyno tuned.
also, make sure your flanges, welds and pipings doesn't have leaks. maybe thats another reason why it feels slower...
Old Feb 8, 2009 | 10:29 PM
Im just not gonna worry about it and get it dyno tuned
Old Feb 9, 2009 | 07:31 AM
90blackcrx's Avatar
Logs ftmfw, I got a new log that routes the wastegate back into the manifold, coming by to test it out on the dynozzzzzzzzzzzz.
OP, your butt dyno is not calibrated.
Old Feb 9, 2009 | 08:02 AM
SovXietday's Avatar
Consider this. You're coming from a cheapo ebay setup. I've personally seen some of these manifolds have smaller ports than the exhaust ports on the head, lol. Ebay is a lot of things, but it was probably restrictive as hell not even just because it was a log manifold. Also, increasing the size of the downpipe will have a huge affect on how efficient the turbo will be, I've seen some cars walk half a point toward the lean side with just a half an inch increase in diameter and some smoother transitions.
So, you put on a well built manifold with a bigger downpipe. Wouldn't surprise me if your AF walked a full point or more towards danger danger. Either way, you'll never know because you don't have a wideband in the car. Just get the car tuned, if all is well it will wake up no problem then.
Old Feb 9, 2009 | 02:30 PM
Silva Bullit DC4's Avatar
LOL!!!
Good one Mikey, that was classic! ;-)
Old Feb 9, 2009 | 02:57 PM
HiProfile's Avatar
So you're an expert tuner or have years taking advanced automotive classes?? A better manifold makes power much easier, meaning you need a lot more gas added. Just 15% more airflow will take you from 11.5:1 AFR's to 13.5:1. That's not only where NA cars start to lose power, that's where turbo motors start to detonate like crazy.
This also assumes your motor is tuned well. A basemap MIGHT get within 10% of the right AFR's, but there's a good chance it was lean in spots already - and you made it FAR worse. As mentioned, if you fubar'd your rings, it will pull even less hard than before.
Your best bet now is to research detonation, do the appropriate checks on your motor/plugs to find it, and do a compression and/or leakdown test. And pray.
Lol, this is like DEI (direct exhaust injection), right? Sounds killer! NO wasted exhaust gases!
Old Feb 9, 2009 | 04:31 PM
Tony the Tiger's Avatar
The car was untuned, so this thread was pointless anyway...
Old Feb 9, 2009 | 06:34 PM
True story i shouldent be complaining about the car without it being tuned.
