Learning how to work the Apexi AVC-R(help)
Old Aug 17, 2003 | 11:45 PM
bey's Avatar
bey
Default Learning how to work the Apexi AVC-R(help)
ok... so.. i got this avc-r hooked up.... and.. its hard as **** to use.... so.. i think i found out how to turn the boost on.. its in settings(why is there setting a and b).. under boost/duty.. but..its in kg/cm2... not psi... what does Duty stand for... ... what does it do if i change it...... also... what is inj duty.... it shows a % number on injector duty...
thanks
Old Aug 17, 2003 | 11:50 PM
Cornbread Jr.'s Avatar
Default Re: Learning how to work the Apexi AVC-R(help) (bey)
I just got mine too and haven't learned how to use it yet, but I do know that Inj. Duty is the duty cycle of your injectors. The % it shows is how much of the injectors you're using. Feel free to correct me if I'm wrong.
Old Aug 18, 2003 | 05:23 AM
DC2R714's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bey &raquo;</TD></TR><TR><TD CLASS="quote">ok... so.. i got this avc-r hooked up.... and.. its hard as **** to use.... so.. i think i found out how to turn the boost on.. its in settings(why is there setting a and b).. under boost/duty.. but..its in kg/cm2... not psi... what does Duty stand for... ... what does it do if i change it...... also... what is inj duty.... it shows a % number on injector duty...
thanks</TD></TR></TABLE>
-The settings are for low boost and High boost (A/B)
-Correct it is not in PSI its close to bar so think of it like that 14.7psi = 1bar
-Duty cycle is how much it takes the AVC-R to keep steady boost (Shown as a percentage)
-Injector Duty cycle is how much of the injector you are using
-The AVC-R takes some getting used to but once you figure it out it is a great boost controller. I love the Learning mode, gear dependent boost, and RPM dependent boost. Best thing to do is download the English manual from Apexiusa.com and read about all the features and how to use them. Good luck.
Old Aug 18, 2003 | 05:56 AM
VTC_CiViC's Avatar
Default Re: Learning how to work the Apexi AVC-R(help) (DC2R714)
Read the manual, helped me out tremendously.
Old Aug 18, 2003 | 07:25 AM
hondahvn's Avatar
i got my boost duty set but now i cant move my boost with out changing the duty whats up with that
Old Aug 18, 2003 | 07:29 AM
DC2R714's Avatar
Default Re: (hondahvn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondahvn &raquo;</TD></TR><TR><TD CLASS="quote">i got my boost duty set but now i cant move my boost with out changing the duty whats up with that</TD></TR></TABLE>
Is it learning mode?
Old Aug 18, 2003 | 09:42 AM
guido-kp's Avatar
not a huge difference, but 1kg/cm^2 = 14.223psi, and 1 bar is 14.5 psi. 1 atm=14.7psi
like i said, not a huge diff
Old Aug 19, 2003 | 05:30 AM
soulless1's Avatar
Default Re: (guido-kp)
So is the (A) setting for low boost and (b) is for High?? Whats a good % to put for the injectors
Old Aug 19, 2003 | 05:32 AM
SuperTeg95's Avatar
Default Re: (soulless1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soulless1 &raquo;</TD></TR><TR><TD CLASS="quote">So is the (A) setting for low boost and (b) is for High?? Whats a good % to put for the injectors</TD></TR></TABLE>
It doesn't matter. YOu pick high and low.
Old Aug 20, 2003 | 11:31 AM
bey's Avatar
bey
i went to the apexi web site and all i saw was the manuals that came with the boost controler.... is there a different manual that tells what does what..
thanks
crxzcracer
Jun 15, 2005 04:56 PM
gzrmoto
Oct 10, 2003 11:54 AM
ek9vboi
Sep 7, 2003 06:35 PM
sxepride
May 13, 2002 10:37 PM
