just got tuned, but...
Old Aug 22, 2009 | 04:34 PM
thegatekeeper14's Avatar
Icon2 just got tuned, but...
ok so i got tuned yesterday and i drove it up and down the street 2x then i trailered it home and went around the block and then parkedit, went out and gave her a little juice and it seemes like it dies out at around 6k i reach boost and the turbo is spooling but the engine seems like its hitting a brick wall, normal driving and acceleration is fine only under heavy throttle!
Old Aug 22, 2009 | 05:29 PM
mtber's Avatar
Default Re: just got tuned, but...
Call your tuner & have him resolve the issue.
Old Aug 22, 2009 | 05:36 PM
Gunmetal_B20_Hatch's Avatar
x2
Old Aug 22, 2009 | 05:37 PM
i dont think vtec is engauging. i checked my oil and connections any idea?
Old Aug 22, 2009 | 06:22 PM
digital sol's Avatar
check vtec solenoid...theres a screen that catches crap...if its gunked up vtec will not enguage...its an easy check...remove 3 bolts and it lift's right off
Old Aug 22, 2009 | 06:42 PM
SovXietday's Avatar
Depending on your setup it could be the turbo running out of breath. But you'd have to ask your tuner.
Old Aug 22, 2009 | 06:47 PM
SMACKMYPAPA's Avatar
WITH WHAT SYSTEM DID HE TUNE WITH?
DID HE TUNE MAP ONLY OR TPS, ALPHA END?
Old Aug 22, 2009 | 06:52 PM
tuned with crome. 3 bar map
Old Aug 22, 2009 | 08:53 PM
b20beast83's Avatar
boost cut?
Old Aug 22, 2009 | 09:52 PM
how do i fix it?
Old Aug 23, 2009 | 05:17 AM
what exactly causes boost cut?
Old Aug 23, 2009 | 08:37 AM
i dont understand some of these suggestions..you just had the car tuned, i can only assume it did not cut out at 6krpm's on the dyno or i cant imagine you would have taken the car home...lets start with the easy questions..
is it mis-firing at higher rpm's?
is vtec enguaging?
start with those and work your way from there...quite honestly i would call your tuner and go over the issues with him...without more info you are shooting in the dark
Old Aug 23, 2009 | 09:24 AM
new plugs, and gaped perfectly the plugs are not wet either. it seems as if vtec is not engauging
Old Aug 23, 2009 | 09:33 AM
slow96lude's Avatar
was it tuned on chrome and what psi are you running. you could be experiencing boost creep and its hittin the boost wall built into the map
if vtec is not enguaging lets check the obvious first
oil level
oil pressure
vtec solenoid
Old Aug 23, 2009 | 10:39 AM
th3pwn3r's Avatar
Was it "fine" at 6k when you got tuned?
Old Aug 23, 2009 | 01:11 PM
im pretty sure it no vtec, but at idle my oil pressure is below 2.0 and driving is about 5.0-5.5 under boost its around 6.0 NEVER over.
im tuned on crome with a brand new built engine and running 9.0 PSI running off the wastegate spring.
my oil level is fine and it seems that if i let the car sit for a bit then drive it its fine but after ten min or so of driving i experince thies issues.
i also have a 3 bar map.
it more dies out at 7k EVERY time and then stutters
Old Aug 23, 2009 | 02:38 PM
Dren's Avatar
It's been said several times already, but I'll give it another shot.....talk to your tuner.
Old Aug 23, 2009 | 05:35 PM
well any suggestions to no vtec?
Old Aug 23, 2009 | 06:26 PM
BoostnEK6206's Avatar
its simple go back to your tuner. you paid him for a reason im sure he doesnt want bad rep on a car so he would be nice and help ya out.
Old Aug 23, 2009 | 06:36 PM
jdm inc's Avatar
x3
Old Aug 25, 2009 | 07:27 AM
slow96lude's Avatar
Are you serious., that is way to low
Old Aug 25, 2009 | 07:29 AM
Bugermass's Avatar
Thats what I was thinking at first, but if its in bar then it makes sence.
Old Aug 25, 2009 | 07:39 AM
slow96lude's Avatar
lets hope its in bar
Old Aug 25, 2009 | 07:42 AM
slow96lude's Avatar
seeing as he is located in the usa then i doubt he is using bar. but you never know. I did the bar conversion for the numbers he said and i would be fine. 6bar=87psi.
