just got back from the dyno hit 300
Old Oct 19, 2003 | 05:27 PM
Black DC2's Avatar
Default just got back from the dyno hit 300
Modified by Black DC2 at 11:32 PM 10/27/2003
Old Oct 19, 2003 | 05:29 PM
Black DC2's Avatar
Default Re: just got back from the dyno hit 300 (Black DC2)
damn pics not working
Old Oct 19, 2003 | 05:31 PM
1CiViC1's Avatar
...://c:/DocumentsandSettings/Owner/MyDocuments/dyno.wpd...
you cant host off your HD you need an online host like imagestation...
Old Oct 19, 2003 | 05:32 PM
twkdCD595's Avatar
Default Re: just got back from the dyno hit 300 (1CiViC1)
unless you setup an ftp on your connection you need to host it from online not offline.
send me the pic and I will post it for you if you want.
let me know.
Old Oct 19, 2003 | 05:33 PM
Black DC2's Avatar
i tried that but i need a jpeg type which is not is a wpd
Old Oct 19, 2003 | 06:17 PM
twkdCD595's Avatar
i tried to convert it to something more veiwable, but I have no clue... I tried omniformat with no luck.
maybe someone else will have better luck...
Modified by twkdCD595 at 1:00 AM 10/20/2003
Old Oct 19, 2003 | 06:58 PM
Black DC2's Avatar
Default Re: just got back from the dyno hit 300 (twkdCD595)
twkdCD595 thanks for trying
Old Oct 19, 2003 | 08:42 PM
Black DC2's Avatar
no one
Old Oct 19, 2003 | 10:33 PM
PureTeg420's Avatar
what are you using for fuel management?
Old Oct 20, 2003 | 12:58 PM
Black DC2's Avatar
Default Re: just got back from the dyno hit 300 (PureTeg420)
Modified by Black DC2 at 11:33 PM 10/27/2003
Old Oct 20, 2003 | 01:25 PM
I Like Boost's Avatar
What do you mean by "Built head" oh and there isn't much diffrence between b16 and gsr cams.
Old Oct 20, 2003 | 01:34 PM
Black DC2's Avatar
Default Re: just got back from the dyno hit 300 (IMPULSE B18C-T)
no p&p just ferrea valves valves springs retainers and valve guides
Old Oct 20, 2003 | 01:40 PM
what size downpipe and exhaust?
Old Oct 20, 2003 | 01:50 PM
falcongsr's Avatar
What is this crap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMPULSE B18C-T &raquo;</TD></TR><TR><TD CLASS="quote">what size downpipe and exhaust?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMPULSE B18C-T &raquo;</TD></TR><TR><TD CLASS="quote">what size downpipe and exhaust?</TD></TR></TABLE>
also tell us what is before the turbo.
Old Oct 20, 2003 | 01:58 PM
espanol's Avatar
Default Re: just got back from the dyno hit 300 (falconGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by falconGSR &raquo;</TD></TR><TR><TD CLASS="quote">
also tell us what is before the turbo.</TD></TR></TABLE>
with those kind of numbers i hope he says the exhaust is stock or maybe he had a banana stuck in the tailpipe.
Black DC2's Avatar
down pipe 2.5 and echaust 2.5 n1 and the manifold is a max rev
Old Oct 20, 2003 | 02:04 PM
.RTErnie's Avatar
You need a BIGGER DOWNPIPE!
Old Oct 20, 2003 | 02:05 PM
VaporTrail's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black DC2 &raquo;</TD></TR><TR><TD CLASS="quote">down pipe 2.5 and echaust 2.5 n1 and the manifold is a max rev </TD></TR></TABLE>
I think the 2.5 inch exhaust is the culprit, as I told you. I have seen gains of up to 25whp going from 2.5 to 3 inch exhaust at your output level
Old Oct 20, 2003 | 02:06 PM
espanol's Avatar
you're making the kind of power my 9:1 gsr motor made on 10 lbs w/ just fmu..??
Old Oct 20, 2003 | 02:09 PM
Black DC2's Avatar
Default Re: just got back from the dyno hit 300 (VaporTrail)
Modified by Black DC2 at 10:47 PM 11/13/2007
Old Oct 20, 2003 | 03:05 PM
kpt4321's Avatar
You need to lean it out at higher rpm's too. You want the most fuel right around the torque peak, because that is when cylinder pressures are the highest. From there, you can taper off some fuel as you approach redline. I bet that would help too.
Bigger exhaust can't hurt!
Torque will always drop, because VE drops after the torque peak. However, I doubt it should drop that much...
Old Oct 20, 2003 | 03:29 PM
racinskittle's Avatar
Default Re: (kpt4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpt4321 &raquo;</TD></TR><TR><TD CLASS="quote">You need to lean it out at higher rpm's too. You want the most fuel right around the torque peak, because that is when cylinder pressures are the highest. From there, you can taper off some fuel as you approach redline. I bet that would help too.
I gotta remember that
red eg1
Oct 6, 2005 10:13 PM
DC2 Rness
Dec 4, 2003 06:53 AM
DLB1994
Apr 3, 2003 05:24 PM
