Jg Edelbrock Manifold Throttle cable bracket problem...
Sup,
im puttingon my GSR jg edelbrock victor x manifold, im about to put that little bracket that holds the throttle cable onto it, i was told if i buy a TYPE R one, it will fit alot easier and better. is this true?
Thanks in Advance
Thanks in Advance
i would also like to know. Im using a ls throttle body and the stock civic cx throttle cable. To get mine to work, I just made a custom bracket.
i just bought an itr throttle cable and bracket piece from acura for 25 bucks after tax (employee pricing
) i don't know if i can use my gsr tb or not though.
everyone says using the itr bracket will make for easier install. some make custom brackets,
) i don't know if i can use my gsr tb or not though.everyone says using the itr bracket will make for easier install. some make custom brackets,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM00SI »</TD></TR><TR><TD CLASS="quote">you bought the cable and bracket? or should i just get the bracket?</TD></TR></TABLE>
you need the cable and the bracket, because the the cable has a biggere spacing between the nut and the hook thing.
Crank
Nov 7, 2008 02:30 PM
88 rex
Jul 9, 2005 07:33 PM
