ITR intake manifold on LS?
Smarter than you
Does the ITR intake manifold bolt right on to the LS with no other modifications? Or would I need to get the skunk2 one?
the flange requires modification. I cut the whole left side of the manifold off right around the runner and had my friend weld on a chunk of aluminum. I just tapped a new water passage and drilled a few holes. Also, the center whole has to be moved down about an inch. line it up with a gasket and you can see the difference.
LD_EGSICK
25
Jul 31, 2003 08:30 PM
SIK IN DA HED
Jun 13, 2003 07:03 AM
iNteKra
Aug 2, 2001 03:58 PM
