intermittent very rich condition. unknown cause/trigger
Old Sep 5, 2010 | 07:49 PM
EG6 Love's Avatar
Default intermittent very rich condition. unknown cause/trigger
92 civic hatch using p28. engine is a 96 fully built turbo gsr.
update 9-8: not the ignitor or coolant temp sensor or the ECU/chip. i have found that as soon as the richening out happens, if i shut the car off and turn it back on while driving, the AFRs return to normal. if the car DIES/STALLS and i restart it, they will remain rich.
my car has been tuned by a reputable local tuner.
situation: car runs with the correct AFR's 85% of the time. doesnt matter how i am driving. However, sometimes my AFR's will drop to 9.9-10.0 and remain there no matter how i drive. after anywhere from 10-60 seconds the AFR's return to normal.
normal idle is a steady 1100rpm. when AFR richens out, idle surges from 500-800rpm.
The car IS actually running rich. the sensor is not giving a false reading.
can some people please point me in the right direction to solving this problem.
thanks in advance, doug
Old Sep 5, 2010 | 07:53 PM
fv8s's Avatar
Default Re: intermittent very rich condition. unknown cause/trigger
chrome ??
Old Sep 5, 2010 | 07:56 PM
builthatch's Avatar
MiG-21 superfan
10-60 seconds is hella long for my original suggestion; i was going to say make sure the diaphragm of your FPR is not ripped; i had that happen one time with an AEM unit and under vacuum it was pulling fuel from the other side of the diaphragm through the FPR vac hose into the intake mani...and it'd be rich as all hell for a short time, but not that long.
Old Sep 5, 2010 | 08:35 PM
Former User's Avatar
A brief rich AFR should not cause a performance problem, such as the idle surge. I think the engine may be misfiring. Check the plugs, wires, cap, and rotor first and also consider the coil and igniter unit.
Old Sep 6, 2010 | 06:00 AM
EG6 Love's Avatar
yes chrome.
we actually stopped our tuning because the ignition was maxxed out, we were losing spark. i know my wires are arcing because they were brand new oem and now with 200 miles they are orange/brown. i had autozone check the ignitor since they are known to go bad on older hondas.
sounds like an ignition is a good place to start.
Old Sep 6, 2010 | 12:48 PM
EG6 Love's Avatar
bump
Old Sep 7, 2010 | 07:39 AM
EG6 Love's Avatar
bump
Old Sep 8, 2010 | 09:27 AM
EG6 Love's Avatar
bump, still havnt been able to find the cause
Old Sep 9, 2010 | 08:29 AM
EG6 Love's Avatar
my tuner is also completely stumped.
Old Sep 10, 2010 | 09:32 AM
EG6 Love's Avatar
bump...what more info do u guys need? ask some questions.
Old Sep 10, 2010 | 07:03 PM
builthatch's Avatar
MiG-21 superfan
i ran it by jeff evans and he really thought it was the coolant temp sensor. he said, "The coolant temp or air temp sensor might be reading off for the time period the car runs very rich. I had a car that had a coolant temp sensor that would randomly read very cold (about 5 degrees) and the ecu would default add 30-40% enrichment trim like i was warming up."
it looks like you eliminated that but i figured i'd ask him.
Old Sep 10, 2010 | 07:21 PM
I would think that if the ECT sensor were falsely reading a cold engine, then the idle speed would increase above that of the warm engine. Instead, the idle speed is decreased. So I think a faulty IAT sensor is a better candidate. However, I don't think the IAT signal affects idle speed.
Also, earlier in the thread, you mentioned arcing plug wires and a spark problem. Has a misfire issue been ruled out?
Old Sep 11, 2010 | 10:44 AM
EG6 Love's Avatar
ANOTHER CURVE BALL. CAR HAS AN OPEN LOOP TUNE!
i agree that the problem im having sounds like an ect sensor giving a false reading sometimes. i will check my wiring again on the ect but i already tested the sensor per honda and i have continuity from the 2 pin connector and ecu.
when i ws tuning my car i was getting spark cut at 16psi and over 6500rpm. so i just turned the boost down to 12psi and i dont seem to have any problems with that much power.
i have heard that the ect has a bigger effect on fuel trim than the iat.
Old Sep 12, 2010 | 09:23 AM
EG6 Love's Avatar
bump
Old Sep 14, 2010 | 12:43 PM
EG6 Love's Avatar
bump
Old Sep 14, 2010 | 12:54 PM
builthatch's Avatar
MiG-21 superfan
i copied this thread into forced induction. for some reason i have a feeling i did something like this before but maybe not.
Old Sep 14, 2010 | 01:15 PM
LightningTeg's Avatar
Community Builder
Check the TPS, ECT, and IAT sensors. You can zero the tipin/tipout and ect/iat tables to rule them out.
I had a weird problem with my car where the car would surge into richness as if I was stabbing the gas (TPS sensor was going on and off). I also had the same problem as you but it was very random and didnt happen hardly at all.
Old Sep 14, 2010 | 01:19 PM
2k.civic.si's Avatar
datalog it and you should be able to see what the problem is.
Old Sep 15, 2010 | 07:23 PM
EG6 Love's Avatar
HERE WE GO:
MAP sensor is not the problem HOWEVER I DID FIND....
with the car off i have 12.6V at battery.
with car running normally i have 14.4V at the battery.
with the car running like **** (very rich AFR) I HAVE NO VOLTAGE AT THE BATTERY.
is this a faulty alternator or voltage 'regulator' i believe its called?
LMK please
b.baker.13
May 17, 2012 08:22 AM
EG6 Love
Sep 17, 2010 09:53 AM
EG6 Love
24
Sep 16, 2010 08:25 PM
EG6 Love
Sep 15, 2010 07:23 PM
7808
Jun 18, 2006 11:24 AM
