Integra '91 + Bosch 044
Old Dec 22, 2012 | 09:48 AM
alperx's Avatar
Default Integra '91 + Bosch 044
I have a turbocharged Integra and my fuel pump is damaged. Since I'm in Turkey - I can't find a good genuine fuel pump in 1-2 days. I found a bosch 044 from a friend who took it out from a Porsche, it's slightly used but in good working order.
Will it be OK if I install this pump ?
Should I install in-line or in-tank - what are your opinions ?
Any tips & tricks about this pump ?
thanks..
this is its pic :
Old Dec 22, 2012 | 09:55 AM
Turbo-LS's Avatar
Default Re: Integra '91 + Bosch 044
044 is an inline pump. It will work but will probably raise your fuel pressure. If you have an adjustable regulator your good to go. That pump will also flow a lot of fuel and is great for turbo applications
Old Dec 22, 2012 | 11:28 AM
alperx's Avatar
I have a B&M regulator. Hope it will be OK.
I'm thinking to make it work directly from outside of the tank without any intank pump.
Old Dec 23, 2012 | 11:09 AM
alperx's Avatar
at which part of the tank should I drill a hole for the pump to suck the gas ?
wernhersey
Oct 6, 2008 03:44 PM
jdm206
Jul 8, 2008 07:23 PM
Green Lude 93
Jul 25, 2004 11:35 PM
veejay
Jul 22, 2001 10:57 AM
