Intake Manifold Tappin
Old May 2, 2005 | 06:41 AM
sadangryboi's Avatar
Default Intake Manifold Tappin
How do I tap an intake manifold for vacuums? Do i just drill and screw in fittings like i am thinking? or is this the incorrect way of doing this...let me know please
thanks
Old May 2, 2005 | 11:44 AM
where can i get these vacuum fittings?
Old May 2, 2005 | 11:49 AM
bostoncal's Avatar
why not just get a T fitting ?
Old May 2, 2005 | 12:03 PM
its a venom like intake manifold with no taps in it for vacuum...i have to tap myself and need to know which fitings i should use and the proper way to do it
Old May 3, 2005 | 10:48 AM
no one?
Old May 3, 2005 | 11:33 AM
N20civicB18's Avatar
Default Re: (sadangryboi)
umm brass barbed fittings.. use very little antisize if you want to be safe... get them at home depot or places like fasenal autozone probaby even sells them in those little help sections and such
centerpunch where you want it, drill the hole, tap it, clean it.
Old May 3, 2005 | 01:51 PM
IN VTEC's Avatar
Default Re: Intake Manifold Tappin (sadangryboi)
http://www.newmantools.com/tapdrill.htm
-see under Taper Pipe Sizes (NPT) for the correct drill bit size to use for the NPT size you want to use.
You'll probably need mostly 1/8" NPT to 1/4" barb and 1/8" NPT to 1/8" barb adapter.
If you need a vacuum barb for the brake booster, it'll probably be something like a 1/4" NPT to 3/8" barb adapter.
You can find all of those NPT to barb adapters at your local or large chain hardware stores.
Old May 3, 2005 | 01:53 PM
simike's Avatar
Default Re: (N20civicB18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 &raquo;</TD></TR><TR><TD CLASS="quote">umm brass barbed fittings.. use very little antisize if you want to be safe... get them at home depot or places like fasenal autozone probaby even sells them in those little help sections and such
centerpunch where you want it, drill the hole, tap it, clean it.</TD></TR></TABLE>
If at all possible take the manifold off to prevent chips from going in the motor. You may also want to buy different sized fittings for different size vacuum hose's.
Old May 3, 2005 | 05:38 PM
sweet thanks guys!
i had to make sure before i did anything.
Listerofsmeg
Dec 2, 2011 10:48 AM
98civicEX
Aug 13, 2009 02:11 PM
ae924agte
Welding / Fabrication
Mar 15, 2008 12:02 AM
Attoir
May 21, 2006 06:36 PM
Just Checking In
May 9, 2003 06:08 PM
