intake manifold and gasket
Old Feb 24, 2007 | 03:04 PM
aryiman98civic's Avatar
Default intake manifold and gasket
hey h-t i just took my intake manifold out and my gasket its pretty much stuck on there. i need to replace it but i dont know the best way to take this off. also what can i put in my intake manifold, liquid wise, so that i can clean it all out. thank you
Old Feb 24, 2007 | 04:22 PM
inspyral's Avatar
For the gasket, the only way I know of to get all of the old paper gasket off is with a razor blade/scraper. You also can get that gasket remover stuff that softens it up to help it come off easier. For the manifold, if you have it off, any good solvent/cleaner should be ok as long as you make you any residue is completely removed before you reinstall it. I think I used a combination of Simple green and carb/intake cleaner when I had mine off.
Old Feb 24, 2007 | 06:49 PM
econorocket's Avatar
Default Re: (inspyral)
Have fun....
It's a bitch to remove all the gunk, even with Permatex Gasket Remover (wear nitril gloves - the **** burns)
Once you have finished the 4 hours of scraping, buy a Hondata gasket and never scrape again!
Old Feb 24, 2007 | 07:02 PM
Bjorn20's Avatar
Default Re: intake manifold and gasket (aryiman98civic)
take it to a table grinder.
I spent maybe 15 minutes scraping off a corner of this rear differental housing on an s10 i think, i then took it to a table grinder (pretty sure thats what it is called) and the entire surface was gasket free within 2 minutes
GsrVtec
Sep 13, 2006 09:53 AM
Shizznaz
Sep 2, 2005 08:07 AM
MR. MIYAGI
Mar 26, 2004 08:01 PM
98HB
Mar 24, 2004 01:28 PM
dualknuttz1
Jan 23, 2004 08:37 PM
