Intake manifold dilemma
Old Apr 8, 2005 | 07:33 PM
legendboy's Avatar
Default Intake manifold dilemma
I bought a B18C head off a local Acura tech last year for $250cdn. He just bought an NSX and was blowing out all his b-series parts. So i got a sweet deal. ITR valves, springs, retainers, LMA...etc...
So it sat for almost a year and i never even looked at it. So yesterday i pull the intake manifold off and realize to my suprise this thing has a full port job !!!
I was planning on using my B16 IM with this head but now i'm not sure if i should take out the secondaries and use this thing!!! What do you guys think?
My setup is:
B20vtec 84.5mm bore
B18C head
CP pistons and Eagle rods
Equal length mani T4
Shooting for 350whp.
Old Apr 8, 2005 | 07:38 PM
Ls1 FD3s's Avatar
Default Re: Intake manifold dilemma (legendboy)
lucky bitch!
B16 IM wont fit GSR head. Buy a Skunk2 , dump the stock ******* IM.
Old Apr 8, 2005 | 07:42 PM
TeStUdO's Avatar
Default Re: Intake manifold dilemma (Ls1 FD3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls1 FD3s &raquo;</TD></TR><TR><TD CLASS="quote">lucky bitch!
B16 IM wont fit GSR head. Buy a Skunk2 , dump the stock ******* IM. </TD></TR></TABLE>
I have a sknuk2 for sale if you need one
Old Apr 8, 2005 | 07:45 PM
quik sol's Avatar
b16 im will only change between b16/type r
Old Apr 8, 2005 | 07:46 PM
eg crunkmonster's Avatar
Default Re: Intake manifold dilemma (TeStUdO)
if the head setup worked for that guy, then it should work for you, id just double check everything and make sure everything is good working order and if it is, use the sucker
Old Apr 8, 2005 | 08:03 PM
legendboy's Avatar
Default Re: Intake manifold dilemma (eg cookiemonster)
aww shiet i didn't know the b16 im wouldn't fit. I thought they were all the same! (i'm using a b16 head currently)
So will the gsr im suck for boost ?
Old Apr 8, 2005 | 08:30 PM
quik sol's Avatar
if i was you, i would get a JG IM for a GSR. Or if your on a tight budget just grab a stock one.
Old Apr 9, 2005 | 12:45 PM
integlspwr2k's Avatar
Default Re: (quik sol)
get the aebs gsr mani they are dirt cheap and works great.
or get a used blox or used skunk mani. you should be okay.
all those manifolds mentioned are below the 200 range.
Old Apr 11, 2005 | 06:41 AM
legendboy's Avatar
Default Re: (integlspwr2k)
So you guys seriously don't think i should use this completely ported out stock gsr intake mani???
EgxHaTcHxGsR
Mar 22, 2019 11:35 PM
2k.civic.si
17
May 12, 2010 08:59 AM
advaneh3
11
Mar 19, 2009 01:44 PM
92b16si
Dec 11, 2006 04:52 PM
finest_GSR
Jan 26, 2006 03:44 PM
