Instead of frostplug can I use a.....
Old Jun 8, 2009 | 02:29 PM
SurferDude905's Avatar
Default Instead of frostplug can I use a.....
Hey guys,
I'm in the process of installing my catch can set-up and I'm getting rid of the PCV. Instead of plugging the pcv hole with a frostplug, will an expansion plug work?
Old Jun 8, 2009 | 02:33 PM
Bailhatch's Avatar
Default Re: Instead of frostplug can I use a.....
A rubber one? I would only use it if it's made out of oil rated rubber.
Old Jun 8, 2009 | 05:10 PM
cleansi's Avatar
i put a rubber plug on mine approved fo high temp and oil it busted once and fell off once and it was tight too i wouldent recomend it but as long as you keep an eye on it i eventually welded it shut
Old Jun 8, 2009 | 05:26 PM
Bailhatch's Avatar
Sounds like a great setup.
I made an aluminum plug for mine with 3 O-rings then put it in with some honda bond.
Old Jun 8, 2009 | 05:37 PM
a1320addict's Avatar
Your best bet..
Old Jun 8, 2009 | 07:19 PM
kreatekustomz's Avatar
where can I get one /\ /\ /\
Old Jun 8, 2009 | 07:20 PM
boost4life's Avatar
expansion plugs are a bad idea, jus use a freeze plug or a nice aluminum plug.
Old Jun 8, 2009 | 07:23 PM
smoovy's Avatar
there are some nice fancy plugs out there but what is the deal with a .20 freeze plug? that's what I have and recommend it. they won't blow out as long as you get the right size and you don't have to spend more than what's needed for something that does the same thing as the the fancy ones....ie..AFI, Z10, B&R.... K.I.S.S.(Keep It Simple STUPID!!!) Spend the money where it counts.
salaamq
Dec 28, 2011 09:59 PM
.RTErnie
Jan 11, 2008 08:31 AM
91accordex16
Jun 24, 2005 06:13 PM
H2nr
Jan 26, 2004 12:02 PM
