Installing Inline Pro 3mm headgasket and ARP Head Studs...Tips?
Old Jun 23, 2003 | 07:11 AM
TurboJesse
Guest
Posts: n/a
Default Installing Inline Pro 3mm headgasket and ARP Head Studs...Tips?
Anyone have any tips/advice for the installation? im putting in an Inline pro headgasket and ARP studs in my b16...thanks
Old Jun 23, 2003 | 07:33 AM
DIRep972's Avatar
Smarter than you
Default Re: Installing Inline Pro 3mm headgasket and ARP Head Studs...Tips? (Mpir3)
I am curious how u set up the cam gears.
Old Jun 23, 2003 | 07:41 AM
TurboJesse
Guest
Posts: n/a
Default Re: Installing Inline Pro 3mm headgasket and ARP Head Studs...Tips? (DIRep)
yea me too I just want to try to get the headgasket and studs in today so i can get the head back on and deal with the cam gears later...The car prolly wont be started for 2-3weeks so i have time to deal with that later..
Old Jun 23, 2003 | 08:19 AM
Adi Radoncic's Avatar
On Fire!
The best tip I think is to use plenty of Copper Spray on all surfaces of the head gasket to prevent leaks from happening, other than that make sure you torque the head down good using the proper torque specs and sequence...
As far as the cam gears go, I had mine zeroed out for as long as I ran the setup besides that the only real way of finding out what the right spot for them is, is to dyno tune the car and dial them in that way..
Adi
Old Jun 23, 2003 | 08:23 AM
intekragsr's Avatar
Default Re: Installing Inline Pro 3mm headgasket and ARP Head Studs...Tips? (newgsr)
I have been told to retard both cam timing 2 degrees when I had a 2mm headgakset on mine.
Old Jun 23, 2003 | 09:25 AM
jinxproof99's Avatar
New User
Default Re: Installing Inline Pro 3mm headgasket and ARP Head Studs...Tips? (intekragsr)
zero them until you dyno it or *** dyno it. everyones set up is different.
hylaxrng
13
Dec 6, 2013 09:56 PM
new_climber
Jan 16, 2009 05:27 AM
donnjuan2point2
Oct 2, 2003 01:12 PM
donnjuan2point2
Sep 30, 2003 07:28 AM
