inline fuel pump better or worse????
Old Jan 14, 2002 | 07:25 PM
c-notecoupe's Avatar
Default inline fuel pump better or worse????
i can get a real good deal on a nos inline fuel pump and i was wondering if it is better to have the inline or the intank or deos it really matter...i'm currently running a crx with a zc /greddy kit a 5lbs. wanting to turn it up to 8-9lbs. i also have full msd with boost timing master......i'm changing out the fmu to an 8:1 disc and 310cc injectors.....but for now i have the 12:1 disc with the stock zc injectors........any input would be nice
-thnx
Old Jan 14, 2002 | 07:35 PM
98hx99b18c's Avatar
Default Re: inline fuel pump better or worse???? (92cxhatch)
If you're gonna use the 12:1 use the inline, if you're gonna use the 8:1 go with the intank.
Old Jan 14, 2002 | 08:34 PM
5gen-hybrid's Avatar
New User
Default Re: inline fuel pump better or worse???? (98hx99b18c)
I'm not a big fan of the inline pumps.Personally i would go with the intank.The whole push/pull action caused by runing an intank and inline pump does not sit rite with me.the holly/walbro 255lph high pressure fuel pump is a good intank choice.i have had no problems with mine.
Old Jan 14, 2002 | 09:10 PM
Mikex25's Avatar
New User
Default Re: inline fuel pump better or worse???? (5gen-hybrid)
the point is if he is using a 12:1 fmu then he has to use a in-line fuel pump, he has no choice but to, since the fmu is going to cause such high fuel pressures that the intank cannot compensate for it.
integranator
Mar 7, 2003 02:12 PM
slwazgsr
Oct 7, 2002 01:59 PM
b18tdelsol
May 19, 2002 07:09 PM
sushibug
Apr 6, 2002 04:50 PM
Teluan
Sep 4, 2001 08:56 PM
