Injectors for turbo
I'm getting ready to turbo my stock b16A2. I need injectors, and I was goin to get RC injectors. Wat cc do i need? Saturated or non? I only want my car to have around 280 hp or around 8-10psi on a T3/To4e.
The difference is the resistance the injector works on.
Low Impedance injectors require a resistor box to be wired into the vehicle to operate properly.
High Impedance (Saturated) injectors do not require a resistor box.
Concerning injector clips, you will need injector clips for any aftermarket injector unless your car is obd1 or obd0 (You can modify the injector slightly to use oem clips).
If you want to save your self some money but not lack quality, look into precision injectors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1cpu »</TD></TR><TR><TD CLASS="quote">no clips or resistor box is needed for these, correct?</TD></TR></TABLE>
correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cameron4776 »</TD></TR><TR><TD CLASS="quote">i kinda wat good name brand</TD></TR></TABLE>
dude, these are good **** i have many miles on them already. i have used precision, rc, and i am running tuner toys now. you can't get better. the only reason i would ever get anything else is because they only have a few sizes. you are just wasting money if you "wat good name brand"
correct.
in all reality, there are only a few companys out there that actually make injectors. and you'll notice alot of injectors look alike, but have different names stickered on them. that is why companys like Precision and RC charge more for theres, they thoroughly flow test and inspect there injectors once they get them from the main makers. (rc might make there own, not sure). I personally bought Delphi injectors (same as precision) because I didnt wanna pay the extra $100+ for the precision name. And they've worked fine for the past 2+years.
-Zol
-Zol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reaction360 »</TD></TR><TR><TD CLASS="quote"> I personally bought Delphi injectors (same as precision) because I didnt wanna pay the extra $100+ for the precision name. And they've worked fine for the past 2+years.
-Zol</TD></TR></TABLE>
i am obd2 and am staying obd2 right now....with the delphi, do they or would they fit like the tuner toys??
will you need a resistor box for these?
will you need a resistor box for these?</TD></TR></TABLE>
i didn't realize you were obd2. the TT, precision, RC, delphi, whatever all fit obd1 clips. you can EASILY modify obd2 clips to work though. thats how i'm running my injectors (modified obd2 clips).
Schister66
Apr 26, 2006 08:36 AM
