Injector Clips
Old Nov 29, 2002 | 06:06 PM
Evil EG's Avatar
Default Injector Clips
My buddy got me some injector clips today at the you pull it yard. When I got home with them I took the shrink wrap off them and the wires looked different...
Does this look right or no?
The two on the left appear to be the right ones but the other two im not sure about....
[Modified by BVM, 9:07 PM 11/29/2002]
Old Nov 29, 2002 | 08:10 PM
20lb.teg's Avatar
Default Re: Injector Clips (BVM)
Well, the Yellow/Black Wires are your power wires and the other color wires (whatever color they are are going to be the wires that tell the injector to open or close). So, as long as the clips fit on the injectors, just wire them up and they should work, if you have any other questions, let me know.
Later,
Sean C.
Old Nov 29, 2002 | 08:24 PM
ChiBoy's Avatar
Are they the same OBD as your car? If so, they should fit fine. Just make sure they fit your injectors before you start cutting wires.
Old Nov 30, 2002 | 12:18 AM
Sonny's Avatar
Those clips look like they are missing the metal retainer clip that wraps around the outside of each clip. They are very easy to lose because they are pretty high tension.
Sonny
Old Nov 30, 2002 | 07:27 PM
Evil EG's Avatar
Default Re: Injector Clips (Sonny)
Yes, they are Sonny what will be the down side to that?
Old Nov 30, 2002 | 07:28 PM
Sonny's Avatar
You can't use the clip without the metal retainer because the metal retainer is what holds the clip onto the injector.
Sonny
Old Nov 30, 2002 | 07:38 PM
Evil EG's Avatar
Well ****!
Old Nov 30, 2002 | 07:41 PM
CzanSOHC's Avatar
summit sells clips.
Old Dec 14, 2002 | 04:50 PM
mskibbz-T's Avatar
Default Re: Injector Clips (CzanSOHC)
summit sells clips.
Do you guys know the part number I would need for a '99 teg LS with MSD 680cc injectors? I've got one of sonny's resistor boxes coming and just need the clips now, thanks guys!
Matt
Old Dec 14, 2002 | 05:00 PM
boostaholic's Avatar
Default Re: Injector Clips (mskibbz)
i can get you a set of injector clips. 20 shipped.
Old Dec 14, 2002 | 05:41 PM
mskibbz-T's Avatar
Default Re: Injector Clips (boostaholic)
Are they new clips? Thanks for the quick reply
[Modified by mskibbz, 6:42 PM 12/14/2002]
Old Dec 14, 2002 | 05:46 PM
They are used clips from an OBD1 vehicle. New clips go for 40 something i think.
Old Dec 14, 2002 | 08:43 PM
T3T495GSR's Avatar
...bump
Old Dec 14, 2002 | 10:13 PM
Sonny's Avatar
You want MSD-2400 from summitracing.com.
It's 16 bucks for 8 clips. You cannot buy 4, unfortunately.
They are nice clips, but they require soldering, and wire installation.
Sonny
Old Dec 21, 2002 | 05:57 AM
mskibbz-T's Avatar
Sonny
Thanks again Sonny! Turns out HondaSwaper has a set of injector clips that I can use. I had assumed I would need to run the resistor box with an EMS, do I need to? Someone mentioned that they thought you could switch from low/high impedance in the EMS injector settings. Does anyone know if this is true?
Thanks,
Matt
Old Dec 22, 2002 | 10:15 AM
lsvtec101's Avatar
any place else besides rc to get clips for my 440cc rc's?
Old Dec 23, 2002 | 07:36 AM
RAWB's Avatar
Sonny
Anyone selling the retainers? I only need 1.
Old Dec 23, 2002 | 09:27 AM
nolimits's Avatar
Standard = SK-25 (8pk...I'm not sure of price or if they have leads)
MSD = MSD-2400 $17/8pk (connectors only)
GM = who cares, they're nearly $20 ea!! (with leads)
Pieko (sturdevandts/pronto) = cross reference SK-25 (sorry, I don't have #)$6.25 ea w/leads
RC Eng = $38/4pk (connectors only)
Do a search...there is a place that sells resistor box w/4 connectors/leads for $40.
Old Dec 23, 2002 | 10:03 AM
Boltz's Avatar
Default Re: Injector Clips (00turbosi)
i got mine brand new from viren, b18bturbo
goldex420
Sep 6, 2013 10:32 PM
scamp91ex
Jan 9, 2013 06:36 AM
RTW DC2R
Jul 17, 2005 12:01 PM
lsvtec101
Mar 8, 2003 03:00 PM
