INEED of plug (catch can project)
im in the middle of installing my catch can and i removed the oil seperater on the back of the block and i was told to get a Z10 plug to plug up the gaping hole but i called them up and they are not going to have the plug for weeks...does anyone know where to get another???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Astig »</TD></TR><TR><TD CLASS="quote">I got mine at Napa, 34.3mm freeze plug. It fits fairly snug, I might seal it with JB Weld just to be safe.</TD></TR></TABLE>
i kinda bent mine outward a little and used hondabond on it. but 34.3mm is correct.
def going to pick that up tommarow, napa is right around the corner...im waiting for my fittings for the back of the block for the catch can, gona hook that up tomarrow. how many of you have breathers on the front of the valve cover? i like the look of it and im sure it helps alot, how hard is that to do would i have to buy a new valve cover?
actually they are a shelf fitting from a local speed shop to me and he did a buy in to have his name put on fittings, only bad thing, to keep costs down they only offer bends up to 90* BUT they are half the cost of the aeroquip. and just as good. i have a 50 -50 mix of his fittings and aeroquip.
summit is great. i order from them all the time.
but this place, bill norris' positive performance, it is like a grocery store for fittings. it is more an automotive plumbing store than a speed shop he hee.
this is his old shop but you see what i mean:
i know they have a coupling press, but i have always made all my stuff, and had a local hydraulics shop make p/s hoses.
friend powdered my vc, and he just masked it well and kinda 2 sepped it when he sprayed the silver over the black.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by utahbmx »</TD></TR><TR><TD CLASS="quote">How do you make it so the Honda symbol and the DOHC stuff comes out so clean?</TD></TR></TABLE>
Just paint over them and hit them later with a di-grinder with an aluminum surface gasket cookie on it...
