I'm buying this turbo setup
Hi there, i'll be buying a turbo kit for my civic si 93 hatch with a d16z6 p28 ecu...
hf manifold (already port matched, include gasket)
tc05-a mitsu turbo (no shaft play)
dowm pipe
oil feed
oil return
adaptor plate welded to turbo
volvo bov
split fire boost guage
feilds afc controler
dsm 390 injectors
charge pipes for crx and 92-95 civic
all vac lines and couplers
all this for 500$ shipped
is this a good deal?
I have one major concern... fields AFC controller.... i never seen this before
what does it look like? is it easy of use? How do you install it?
This will be my first attempt at turbo charge a car because i wont buy
the black Trans-am 77 i was looking for... gas is too expensive here (almost 1$cnd/liter)
post your comment!
Modified by labatt50 at 5:30 PM 5/10/2004
dowm pipe
oil feed
oil return
volvo bov
dsm 390 injectors
post your comment!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Flip »</TD></TR><TR><TD CLASS="quote">will you be doing your own tuning?</TD></TR></TABLE>
yep basically...
i plan on runing 5-6 psi
yep basically...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by labatt50 »</TD></TR><TR><TD CLASS="quote">
yep basically...
i plan on runing 5-6 psi</TD></TR></TABLE>
oh ok, so you'll be using some sort of wideband right? Try out the fields afc, if you dont like it....socket your p28 for uberdata (uberdata is free LOL). Not sure if it helped, just an idea since you were tuning it your self
yep basically...
