Ignition breaking up under higher boost
I've got this problem with the engine missing at higher rpms. Problem becomes worse as the boost increases. New plugs, BKR7E-11. Tried gapping them down to 20 and the problem is still there. Cap and rotor are good, not new, but in good shape with little to no carbon build up on the terminals. Car is tuned to 12:1 A/F ratio in boost and runs great under anything other then WOT. Problem is intermittant but 9 times out of 10, its noticeably missing up past 6k. Currently has Kragen wires on it, was going to get some NGK blues to begin with. Any other ideas? People whom have experienced this problem? Car is currently at 8psi. 10psi is pretty bad. Almost to the point where you notice no gains between 8 -> 10psi increase.
I would speculate it's the distributor or the battery/alternator. Put a volemeter on the battery and monitor voltage when you wind it up. If voltage sags that's the problem, if not then the dist is suspect. Or the dist/ECU circuit.
Of course, plug wires are also suspect. How about engine temps? Stable? Cooling system ok?
Any codes?
Any codes?
Any codes?
Any codes?
Battery voltage dropping will cause a motor to lay down @ WOT. The higher performance the motor, the more it can cause issues.
Is it leaning out? Did it run good, then develop the problem? Check fuel pressure too.
Speaking in general terms here - a boosted motor is fragile. If it's leaning down that's bad. Or detonation. So, be careful with it when testing.
Good luck with it!
Try gapping your plugs closer, like nearly no gap and report back. You might still be blowing out the spark. If not, I'd suspect dizzy. Both situations have happened to me (gap too big, and then dizzy went a year later)
I logged the battery voltage at WOT in second and third. Held solid at 13.6volts.
TPS also held solid at 4.55volts
FPR vac line is brand new, didn't see any signs of wear. It does have the BOV also tapped off that line as well.
I'll close the gap more and see what I get. If it does solve, should I suspect weak coil?
Shrinking the gap helped my break up under boost problems, but didn't solve them. I had a basically brand new set of Magnecor 8.5mm wires (1,000 miles on them). I tired everything. When I changed to a brand new set of NGK blues, all the issues were gone.
What map sensor are you running, how old is it and whats it look like reading wise ? Ive seen a bad map do this when all the obvious things like plug gap coil and distributor are confirmed good. Happend to me and several other people i know with a motorolla 2.5 bar
Map sensor is an Omnipower 3 bar. It seems to read nice and steady from datalogs. Its not too terribly old. I used it on my last setup I would say 4k miles.
i had break up problems with my ls also i gapped my plugs to 15 i also bought a msd external coil and ngk plug wires fixed all break up problems even at higher boost
Im going to regap the plugs tonight when I change the oil. NGK blues are on order. Prolly get them in a weeks time.
if gapping them smaller doesnt work and all the ignition components are in 100% working order i suggest it could be ONE of your injectors...i would have all cleaned dont think it cost too much...goodluck
If you run aftermarket coils off of stock ignitor it usuallycalls for tighter gaps from my experience anyhow. When I went from stock coil to msd coil I had to go from a .024 to a .020
if your running an ignition box however then you should be able to widen the gaps up a decent amount and get a better fuel burn without spark blowout. Currently running summit racig digital ignition box with mad blaster ss coil and the spark increased dramatically with the diital box and less strain on the ignitor which makes it run cooler so no failures
