ID Injectors Voltage compensation?
Old Dec 16, 2012 | 06:41 AM
Steeve_Civic's Avatar
Default ID Injectors Voltage compensation?
I've changed my 750 RC injectors to ID 1000cc.
I use Hondata S300 and would like to know If there is a difference in the injectors voltage compensation?
I saw this scale on ID Website but it matches only static fuel pressure?
Thks
Old Dec 16, 2012 | 07:44 AM
Turbo-LS's Avatar
Default Re: ID Injectors Voltage compensation?
Yes there is a difference. Completely different injector. Input the dead time milliseconds/voltages into s300. It will be easier to tune and will run better with the proper voltages input into the scaler. Just add three decimal places to those numbers.
Old Dec 16, 2012 | 08:44 AM
OK thank you
At idle, I have a fuel pressure set at 50 PSI with the vacuum line disconnected and 45 PSI when connected.
What are the good values?
Thks
Old Dec 16, 2012 | 09:11 AM
Turbo-LS's Avatar
If static pressure is 50 then use those those settings
Old Dec 16, 2012 | 10:06 AM
OK, I tried and it's better when starting.
Do I need to change Fuel Trim?
I used this values when 750cc
Overall Fuel Trim: 0%
Cranking fuel: 20%
Thottle tip: 2%
Old Dec 16, 2012 | 10:19 AM
Turbo-LS's Avatar
Change from 750 to 1000cc and then retune it.
Old Jan 13, 2013 | 10:51 AM
Correct, thank you, it works nice but I need to retune all the map
bnmm
Feb 8, 2011 05:54 PM
tnsxsear1
Sep 11, 2004 09:01 PM
7rrivera7
Aug 21, 2003 10:07 AM
turbosi03
May 27, 2003 06:34 PM
niedejb
Mar 28, 2002 02:06 PM
