IAT mounted in charge pipe with turbo setup?
Old Mar 20, 2005 | 01:15 AM
IDriveHonda's Avatar
Default IAT mounted in charge pipe with turbo setup?
I am finally in the process of putting my turbo on and I am trying to figure out if I am supposed to put my IAT sensor into the charge pipe that runs to my throttle body like it is in the stock intake arm. It is a 99 Civic and I just don't recall seeing it in any pics of other peoples setups. I tried to search but couldn't find anything. Help me out if you can. Thanks.
Old Mar 20, 2005 | 01:43 AM
mrx's Avatar
mrx
Default Re: IAT mounted in charge pipe with turbo setup? (IDriveHonda)
Why do you want to do that?
Old Mar 20, 2005 | 01:46 AM
Default Re: IAT mounted in charge pipe with turbo setup? (mrx)
I am not sure if that is what I am supposed to do or not, that is why I am asking.
Old Mar 20, 2005 | 01:58 AM
mrx's Avatar
mrx
just think about it... if you mound the IAT Sensor in the charge pipe you read cooler air temperature as in the intage manifold. so your ecu will enrich the mixture...
i've never seen any turbo setup with the iat sensor at a differenct place, only if your intake mani didn't have any mounting holfe for the iat... not normanly you won't need any change with proper tuning.
Old Mar 20, 2005 | 02:18 AM
honda9369's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrx &raquo;</TD></TR><TR><TD CLASS="quote">just think about it... if you mound the IAT Sensor in the charge pipe you read cooler air temperature as in the intage manifold. so your ecu will enrich the mixture...
i've never seen any turbo setup with the iat sensor at a differenct place, only if your intake mani didn't have any mounting holfe for the iat... not normanly you won't need any change with proper tuning.</TD></TR></TABLE> i put mine on the intake side but it doesnt really matter untill the boost blows it out. and as far as enriching the mixture,well thats where tuning can solve that problem. so u will run rich untill tuned which is alot better than running lean
Old Mar 20, 2005 | 08:14 AM
mrbsponge's Avatar
the only issue with putting it in the charge pipe, is getting it to stay in under boost.
i did this on my 99si, i put the IAT probe in the charge pipe, took a zip tie, went around the pipe, between the 2 wires ont he sensor, and bingo, DONE.
unless you convert to the OBDI style manifold with the bolt in sensor on the manifold you need to do use this method.......
just dont wrap a bunch of tape around it and shove it in the hole, thats ghetto and the tape ends up in the motor..............
Old Mar 20, 2005 | 08:41 AM
D-tuned's Avatar
Default Re: (mrbsponge)
i have a GM AIT in my charge pipe a few inches before the throttle body. the reason why I put it there is so that I can see the air temps actually going into the engine under boost and vacuum. I also have another AIT before the intercooler. I wouldn't recommend putting a factory Honda AIT in the charge pipe because it will get heat soaked. Why the sensor get heat soaked you will get in accurate readings
Old Mar 20, 2005 | 09:33 AM
turbosi03's Avatar
Default Re: (2000civicsi)
I have a machined block I had made for mounting the acura mani mount sensor on the charge pipe. not using it on my new setup if you want it
here's the sensor I used you can pick up at acura...
works great
Old Mar 20, 2005 | 12:32 PM
Default Re: (turbosi03)
Thanks for the replies, I coincidentally have a Z6 manifold on my Y7 which has the sensor in it also so I guess I will just use that one to simplify the matter.
Old Mar 20, 2005 | 01:01 PM
nfn15037's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">I have a machined block I had made for mounting the acura mani mount sensor on the charge pipe. not using it on my new setup if you want it
works great</TD></TR></TABLE>
LOL SOOOOO over-engineered.....I like it!
Old Mar 20, 2005 | 04:04 PM
dornon13's Avatar
Default Re: (nfn15037)
yeah i left mine out not really knowing what to do with it and i got to the dyno for the tune and he was like you didnt put the iat sensor in i was like i didnt know i needed to...lol
Old Mar 20, 2005 | 04:17 PM
mchuang's Avatar
if you use a type r manifold you can just rewire it and connect it on the manifold that is what i did on my 2000 si
Old Mar 20, 2005 | 05:13 PM
Dampach1's Avatar
Default Re: (mchuang)
Just put it in the air intake for the turbo.
Old May 17, 2005 | 05:53 PM
CivicMike's Avatar
Default Re: (Dampach1)
what the difference between mounting it before and/or after the turbo. (From what i know of uberdata./crome does IAT even have any effect on calculating fuel ratio?) im debating if i need an autometer air intake temp gauge if I can datalog IAT.
Old May 17, 2005 | 07:45 PM
adictionbass's Avatar
Default Re: (CivicMike)
well, the difference between putting it before and after the turbo would be the fact that the air temp increases when it gets compressed.
So putting it before the turbo, too cold of a reading
after the turbo, but before the intercooler, to warm of a reading,
in the intake manifold, can get heat soaked,
A few inches from the throttle body on the charge pipe, just right
Old May 17, 2005 | 09:09 PM
saxqtzk's Avatar
Default Re:
is this what you're referring to?
this is Marauder's setup:
http://www.turbod16.com/album_page.php?pic_id=204
If it is what you're talking about edelbrock places it on the air inlet on the turbine side.
Old May 17, 2005 | 10:03 PM
BlackCRX's Avatar
i stabbed a hole at the coupler right before the tb with a screw driver, then poked the iat in tehre, and zap strapped it down
its ghetto and it works :D
Old May 17, 2005 | 10:23 PM
HYBRID_H@TCH's Avatar
Default Re: (BlackCRX)
GM air temp in the charge pipe= less errors due to heat soak...
Old May 18, 2005 | 05:06 AM
CivicMike's Avatar
Default Re: (99Hybrid_Hatch)
how do you run the GM AIT? it has the same output as the Honda IAT?
Old May 18, 2005 | 06:01 AM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dampach1 &raquo;</TD></TR><TR><TD CLASS="quote">Just put it in the air intake for the turbo.</TD></TR></TABLE>
OBD2 ECUs 'expect' the IAT sensor to be in the intake pipe (cooler temps than the intake manifold) and OBD1 ECUs expect it to be in the Intake Manifold (expect warmer IATs) and they account for this factor differently.
The calculation that happens inside the ECU is a little bit different for each generation of ECU.
I say try a variety of locations and see which gives you the best drivability while tuning.
Old May 18, 2005 | 09:43 AM
99 hybrid, what EMS are you running? Im going with the AEM EMS and the GM sensor is probably alot cheaper the the AEM IAT.
Old May 18, 2005 | 10:50 AM
DragSource's Avatar
I'm confused. I made it through my first DIY turbo kit without having to re-loc the IAT. . . under what curcumstance is one required to do this?
Old May 18, 2005 | 10:57 AM
fjt's Avatar
fjt
I have a Y7 with a Z6 I. Manifold and my IAT is in the Charge pipe..I drilled a hole close to the TB and JB welded in there...No problems by running it there.
Old May 18, 2005 | 02:53 PM
DragSource's Avatar
Bump - still confused.
Old May 18, 2005 | 03:18 PM
alpha's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">
LOL SOOOOO over-engineered.....I like it! </TD></TR></TABLE>
Over-engineered by an engineer though
