hp #60-1
Old Oct 17, 2006 | 06:31 PM
  #26
racin jasin R's Avatar
Default Re: (T4eg)
wow that is good
Old Oct 17, 2006 | 09:13 PM
  #27
Garage 808 Hatch's Avatar
they are "rated" to 580.
Old Oct 17, 2006 | 11:49 PM
  #28
Default Re: (Garage 808 Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch &raquo;</TD></TR><TR><TD CLASS="quote">they are "rated" to 580.</TD></TR></TABLE>at what psi???
thanks
Old Oct 18, 2006 | 06:27 AM
  #29
anothaRRR's Avatar
Default Re: (dunkd)
t4 .68a/r
Old Oct 18, 2006 | 03:42 PM
  #30
fmfkid250's Avatar
mines a t3 .48 and i sqeezed 517 whp on a dynojet at like 31
stock gsr head 9.5:1 2.0l
Old Oct 18, 2006 | 07:32 PM
  #31
Default Re: (fmfkid250)
thats some # great tune!
Old Oct 18, 2006 | 07:53 PM
  #32
spooncivic1's Avatar
so basically you are looking at mid/high 400's with a 2.0L
i'm gonna be building a 1.8L with this turbo soon, hoping for mid 400's with the T3 housing
Old Oct 18, 2006 | 08:34 PM
  #33
dunkd's Avatar
Default Re: (spooncivic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooncivic1 &raquo;</TD></TR><TR><TD CLASS="quote">so basically you are looking at mid/high 400's with a 2.0L
i'm gonna be building a 1.8L with this turbo soon, hoping for mid 400's with the T3 housing</TD></TR></TABLE>
my garrett t3/60-1 .63 NOT HO--- max'ed out around 530'ish.
Old Oct 18, 2006 | 08:40 PM
  #34
on pump (93oct.)?
Old Oct 18, 2006 | 09:00 PM
  #35
dunkd's Avatar
well it becomes how ballsy you are and how much u trust your tuner to go on pump gas.
I know Jeff Evans stops at 425 on pump for his customers to keep it safe. anything above that is probably approaching your limits.
Old Oct 19, 2006 | 07:07 AM
  #36
fmfkid250's Avatar
pump gas is overrated
Old Oct 19, 2006 | 09:15 AM
  #37
B18c1turboedEK's Avatar
Default Re: (anothaRRR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anothaRRR &raquo;</TD></TR><TR><TD CLASS="quote">t4 .68a/r</TD></TR></TABLE>
Running his exact same turbo on my car i made 635hp at about 28psi!!! Im going to go back and turn up teh boost some more, i will say this i was highly impressed with this turbo..
Thanks AnothaRRR for letting me borrow your turbo and making more hp than you on it !!! hahahaha
Old Oct 19, 2006 | 09:59 AM
  #38
BoostR41's Avatar
Default Re: (B18c1turboedEK)
I am not sure of my WHP at 23psi since it is street tuned there on 112, but on 18psi it was at 461whp and at 1 bar it was at 401whp
Old Oct 19, 2006 | 10:42 AM
  #39
**** really!!!
i guess i changed that i hit 635 on it!!!
Old Oct 19, 2006 | 04:20 PM
  #40
this are some large hp #
Old Oct 19, 2006 | 06:25 PM
  #41
JG-Fabrications's Avatar
Default Re: (racin jasin R)
30 psi on the stock s2k motor made 620 whp
-James
Old Oct 19, 2006 | 06:26 PM
  #42
Default Re: (JG-Fabrications)
Specs on the turbo
S comp housing (70 ar 4" inlet 2.5" outlet)
.63 ar exhaust housign stage 5 wheel 3" downpipe
-James
Old Oct 22, 2006 | 12:15 AM
  #43
Default Re: hp #60-1 (racin jasin R)
60-1 garret
Old Oct 25, 2006 | 01:17 PM
  #44
engine in the car...
Old Oct 25, 2006 | 05:54 PM
  #45
blackeg's Avatar
anyone running this with a t3 hotside on an 81.5mm b series?
Old Oct 29, 2006 | 10:29 AM
  #46
SpeedImage3's Avatar
T3/T4 60-1 Turbonetics, LS-GSR head/JG Mani,BDL 70MM. std bore 428whp 310ft lbs 15psi. Pump.
Old Oct 29, 2006 | 02:55 PM
  #47
blackeg's Avatar
Default Re: (SpeedImage3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedImage3 &raquo;</TD></TR><TR><TD CLASS="quote">T3/T4 60-1 Turbonetics, LS-GSR head/JG Mani,BDL 70MM. std bore 428whp 310ft lbs 15psi. Pump.</TD></TR></TABLE>
exactly what im looking for. good #'s
Old Oct 29, 2006 | 03:59 PM
  #48
Blown90hatcH's Avatar
Default Re: (paul vang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paul vang &raquo;</TD></TR><TR><TD CLASS="quote">Im not even done collecting parts yet dude. lolz</TD></TR></TABLE>
yeah, it's only been 5 years. Still got 5 more to go.
Old Oct 29, 2006 | 05:03 PM
  #49
Default Re: (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">
exactly what im looking for. good #'s </TD></TR></TABLE>hell yeah me to....
Old Oct 29, 2006 | 08:58 PM
  #50
Default Re: (Blown90hatcH)
and for ***** n giggles, I used the greddy emanage to tune.
Walbro 255lb
800CC Bosch injectors
SX Adj. FPR with S.S lines to rail etc.
SP Engineering ram horn turbo manifold
Turbosmart 38mm wastegate
Precision Intercooler
3" DP and greddys 3" exhaust
Aluminum 2.5 intercooler piping
Greddy RS BOV.
GSR Head (no porting or polishing)
stock valves
Manely springs & Retainers
GSR CAMS
JG Manifold
BDL 70MM Throttle body.
LS Block
JE 8.5:1 Compression std bore pistons
bensen sleeves
Crower billet rods
GE LS/VTEC KIT
OEM Bearings, GSR PUMPS
GE Headstuds.
MSD 6AL, COIL.
GSR Tranny, Type-r LSD. Comptetion Stage4 clutch.
Omni-power coilovers,camber kits and control arms.
Goal was to have a simple setup, daily driver and reliable.
Ran the car at the track with a best of 12.2@120mph 2.0 60' on 24"slicks with full interior weighed at 2700lbs with me in it. Timing was set at 2degrees base timing. I was messing around with the distributor after the dyno but never thought I should check it again It was set right at 16degrees base timing before the dyno and it was tuned for that. When race season was over and I decided to do a tune up on the car, thats when I found out the timing was off and what a difference it made.
