how to remove OEM fuel rail fitting ?
Old Jul 7, 2011 | 04:54 AM
Charlie Moua's Avatar
Default how to remove OEM fuel rail fitting ?
I wanted to use a male to male M12 x 1.25 to -6an fitting on the end of OEM fuel rail.
Q:
1) so how do you remove the stock fuel rail inlet fitting?
2) is it threaded or just pressed in with some sort of sealer from the factory?
* I tried heating it up with MAP gas and using VICE grip already.
* I went to Ace Hardware but they didn't have the right nut (was going to try to use 2 of them & try to turn if off)
Charlie Moua
Jul 8, 2011 08:48 AM
Charlie Moua
Jul 7, 2011 06:52 AM
Charlie Moua
Jul 7, 2011 04:54 AM
turbo-crx
May 20, 2009 10:16 AM
B18EG6
Jan 8, 2003 12:24 AM
