How Much/Where to get the plug for the GM 3 Bar Map Sensor
I just ordered my 3 bar Map sensor and I realized that it prolly doesn't come with a plug for it. Where do you get those. And how much do they cost.
Thanks-
Corey
Thanks-
Corey
GM AC Pressure switch plug was used (Conduct Tite part number 85146 from Pep Boys, about $10)
courtesy of hondata.com
Send a PM to "gitwidit"
he is the parts manager at Holman GM in Cincinnati.
I bought both the sensor and pigtail from him
the plugs are about 10 at pepboys. I couldnt find that part number at pepboys so i bought a tps sensor plug for a gm at autozone. I modded it a little to work...it was pretty easy tho.
I couldn't find the part at Pepboys... Anyway, I just got the map Sensor, how the hell does that bolt up to your throttle body... The holes for the screws are way further apart than stock.
Here is the part number that i got... 12223861
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95c1v1cs1 »</TD></TR><TR><TD CLASS="quote">I couldn't find the part at Pepboys... Anyway, I just got the map Sensor, how the hell does that bolt up to your throttle body... The holes for the screws are way further apart than stock.
it doesnt bolt up. you either leave the stock one on or plug it. then you mount the map sensor as close to the intake manifold as possible and run a vacuum line to the intake manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotorMatrix.com »</TD></TR><TR><TD CLASS="quote">
it doesnt bolt up. you either leave the stock one on or plug it. then you mount the map sensor as close to the intake manifold as possible and run a vacuum line to the intake manifold.</TD></TR></TABLE>
I did a search and understand now. Thanks guys.
has anyone Hard wired their sensor up or do you find plugs?
bump... anyone have pics of how they mounted the 3 bar? i didn't even notice they were different sizes...
anyone plug theirs? im going to have to, as i don't have a stock map sensor right now, and buying one as a plug is kinda stupid
so yeah, pics r00><0rs
Type-ARR
Jul 7, 2003 02:58 PM
