how much boost
Old Jan 15, 2003 | 04:55 AM
jdmtim's Avatar
Default how much boost
on a factory ls w/ high compression piston. what is the max amount of boost you should run
Old Jan 15, 2003 | 05:10 AM
CRVRX's Avatar
Default Re: how much boost (jdmtim)
How much compression ? 10,11,12 to 1.
Old Jan 15, 2003 | 06:23 AM
BudaKai's Avatar
Umm, how much money do you want to spend first of all? Then what compression, and how long do you want to spend tuning? The higher the compression goes the more money your going to spend keeping the intake charge cool as possible, and the more time your going to need for tuning it so it doesn't grenade.
[Modified by tzsir, 9:25 AM 1/15/2003]
Old Jan 17, 2003 | 05:07 PM
jdmtim's Avatar
Default Re: how much boost (tzsir)
sorry it took so long to respond, works been crazy lately. Currently I got p73's on stock ls rods. Should I lower the compression say like back to stock 9.4:1 or should I go even lower like 8.5:1. My plan is to run approx 12-15psi SAFELY.
Old Jan 17, 2003 | 08:05 PM
ekb18c's Avatar
Your compression is low enough already. Just make sure you have enough fuel.
white2draccord
Apr 28, 2008 03:26 AM
slowcrx954
Nov 23, 2006 07:49 AM
SiRay13
May 30, 2006 11:48 AM
TehMoonRulz
May 16, 2005 01:15 PM
madcrossover
Dec 13, 2004 06:40 AM
