How many of you are running a boosted honda with or without LSD
Just wanted to know how are you managing traction without an LSD. I am looking to buy an OBX LSD but wanted to know if its worth the money. Back in 2009 I had a turbo type r 327whp and 256 torque, since the type r came with LSD, I remembered I still had traction issues first and second gear. Anyways what I am getting to is that I have never driven a turbo honda without LSD, and wanted to know how you guys manage the wheel spin and if it makes a big difference having one?
Re: How many of you are running a boosted honda with or without LSD
Having more tire and a stickier compound will help greatly. At higher boost levels, like 400+, boost by gear is a must.
Originally Posted by Aradin
(Post 50648673)
No. Never have so I don't really have a basis to judge both sides. I have had setups from 250-450whp in my Accord and am currently around 350whp. All with open diff transmissions. Current trans is a USDM H23 trans, which is middle ground gearing in H/F series land. It blows the tires off first and second this time of year but doesn't pull funny or anything unless it's wet out. Summer time it will dead hook second gear with no problems.
Originally Posted by Todallybuilt
(Post 50648664)
Originally Posted by LightningTeg
(Post 50648751)
Don't buy an OBX. The new ones are plagued with run-out issues. The old ones (which I have had since 2007) were able to be taken apart and rebuilt with new washers.
I am running the mfactory and it has been great so far, 2.5 years and counting.
I am running a Quaife LSD. I have had many transmissions in this car with and without LSD. I cut the same 60ft either way. It helps a whole lot around turns etc... but just launching from a dig...not so much.
Learn about the different TYPES of LSDs used for their purpose. for 400+whp BBG is NOT a must, if the purpose is different than 1/2 mile, 1 mile or drag racing.
A Type R Torsen, acts differently than a Quaife Helical, or MFactory Gear type. This will help.. Limited slip differentials and their types Basic Mechanics on Automotive Differentials What is a Torsen LSD? This works better than a simple "poll" or "what do YOU use?" type of thread. Good luck. |
400+ here and i think bbg is not a must. definitely a good feature for some who cant control the pedal. what i notice goin from non-lsd, to having a lsd, is more managable wheel spin. i had wheel spin before i swapped my lsd in, but the amount of wheel spin was far worst. however im also on falken ziex 512s lol
09 mfactory helical here also |
That's what I meant really. Poor wording on my part. Not an absolute necessity, just more of a very welcome convenience. Limiting the shock load to the tires with torque management is beneficial at power levels below 400 even. All depends on the setup.
I'm running a stock, non-LSD gsr tranny. BBG is set up. MH 235-60-15 tires up front. I have no traction issues at 415 whp or 512whp with my current set up. In fact, I have scratched getting an LSD tranny off my list (for the time being) because it runs so well. Not daily driven but driven 2-4 times a week.
I think for most drag-raced Hondas, LSDs arent a complete necessity because for the most part Hondas torque rating isnt that high and if it is, it's way up in the rev range
For road race/auto x Hondas though, it's a different scenario |
Originally Posted by AZ_CIVIC
(Post 50648786)
Front mount traction bar will help too.
410WHP here with H22 non-LSD. I've had no issues and the rare burnouts I do always spin both tires. I've never had a 1 wheel burnout before or traction issues. Most say with LSD you feel the pull in the corners the most. I imagine launches will improve but I don't do that with the car. And track performance will increase but I don't do that either. I do realize that the tranny is the weakest link so I am in the process of building a T2T4 with factory LSD and carbon syncros. Also on the car currently...
- ESP front traction bar - 215/45/17 rubber - Stage 4 Bully clutch Hope this helps. |
Originally Posted by Raf99
(Post 50657510)
I have a stock em1 trans with an open diff and I ran 11.69. @117 with 321whp and 265ft-lb
Spinning at lower gears really depends on turbo size, assuming you covered all the basics (nice suspension, tires, LSD, alignment, traction bar)... If you have a smaller GT28/GT30R or similar sized turbo, it comes in too abrupt at the lower RPM's and the power transition sucks, which makes it really hard to stick the power to the ground.
The transition of power is really important, as sometimes it is much better to sit at 170-200 lb-ft of torque for a few tenths of a second and then ramp up to grip most of the gear, rather than have all the torque kick in abruptly. Slower acceleration is always better than almost no acceleration (spin) I did a lot of tweaking to get the boost soft in 1st/2nd gear so the tires just haze all the way to redline. The more redline you have, the easier it is to control it. The engine has to be efficient too, so there is easy control of power and it doesn't rely on the turbo to "wind up" to make some sort of power at the lower gears. Picture your best car for street use is something that reflects a strong K20 all motor car for 1st and 2nd gear (which has engine response / throttle control and lots of redline as main advantages), and then when its time for 3rd gear, it becomes a 500+ WHP beast. I usually manage 1st/2nd soft enough to keep up with most cars from 0-50 mph and never worry about blowing the tires loose so at least it is consistent, and then just ram all the power I got in 3rd gear which always sticks well. With our Honda's power to weight and gearing/redline advantage, we usually can pull back from almost any car within the same power level by 3rd (if you don't, time for more power dude). |
Originally Posted by Tony the Tiger
(Post 50658262)
