How to idle 550 injectors without standalone?
Ok, so I am needing some bigger injectors anyway (as soon as I figure out why my throttle is still sticking after almost a damn year) and there's that great deal on RC 550s...
I have the VAFC and I'm going to be using the "trick" with no FMU and no check valve. Will the VAFC idle these things or would I also need to lower the base fuel pressure?
man... i wouldnt even try it. just go with the Hondata. why not? im sure you can idle with the 550s... you just gotta play with the AFC to find a good setting. use some of the money you get from selling the fmu, fuel pump, missing link and slap on another $300 and you got yourself a Hondata.
It probably wont work without lowering the pressure. The vafc only goes down to -50%, and with 450s your already @ -40%. It might work, but you will have NO window for adjustment. Your gonna be at the edge. Then again, it probably wont take too much of a drop in pressure to correct...
If you already have the Vafc, then i say just buy the injectors and try it. If it doesnt work out you can always go back to your old setup and then look into a hondata/etc.
Yeah but I'm OBD2 so I'm looking at a lot more than $500 to go Hondata. Believe me, I woudl do it.... but I'm also considering a B18B swap within the next year.
Then why the injectors?? I mean you already have a set of 450's right? You don't stand to gain anything by going with 550's on a D16 (unless you had plans to build to it hell, which you don't).
Keep the idle set to at least 1000 rpm.
Run about 25-30 ppsi fuel pressure.
Drop the VAFC to -49%.
It will run idle nasty, but it will idle.
Good luck, and I mean that, Good Luck.
Randy
Randy
No, I have 310s. The 550s are cheaper than the 450s. Also, I plan to get 300 WHP whether I build this D16 or a B18, so I need larger than 450. I also don't want to get 10 year old DSM injectors. They might be cheap and they might work good, but I want my stuff to be top notch.
Get some Used DSM 450cc injectors and a Resister Pack out of a 89-91 crx or integra. Cost you about $75
if you want your stuff to be top notch then you should save up the $ for a standalone. running a standalone with DSM injectors is more "top notch" than running 550cc injectors with some alphabet soup piggy-back setup.
oh and by the way, RC injectors aren't exactly "top notch" either, but I personally swear by them
-Xerxes
-Xerxes
Ok, that was kind of smart *** and I would have punched you in the mouth if you said some **** like that to me in person, but ok.
A. No ****, of course I want a stand alone like everybody else. I don't have the money right now. I don't want my car plans to be on hold for another who knows how many months until I can afford a stand alone. Thanks for the insults on the "alphabet soup" thing though. That was very informative and helped to answer my question.
B. Running 10 year old DSM injectors is not my idea of top notch, whether they are in a Honda with aftermarket engine control or a Ferrari.
C. RC Injectors are NEW (because I will buy them new) and work very well. Unless you know somebody that has had problems with them? Exactly ... that's my idea of top notch.
Now, I hate to be a ***** to anybody on this board, but damn your post did not help anybody one bit. All it did was **** me off. After I punch you in the mouth, we can be friends again.
Ok #1, turn your sensitivity level down a couple notches. What he said was alot more helpful than your taking it for. I don't know if your having such a titty attack because it's not what you wanted to hear or what, but it's true. You said you wanted a "top-notch" setup, then why are you relegating yourself to using piggybacks instead of a standalone? That's YOUR contradiction, he just happen to catch it.
In any event, I agree with him, DSM injectors are good quality. Get a set that are in good shape and have them cleaned by RC and you'll be in good shape. How often do you hear of injector failures (assuming the injectors aren't over worked i.e. 100% duty cycle!), it's a rareity at best. I'd MUCH rather spend $50 on DSM 450's and a $30 resistor pack so I can save some $$ for Hondata, than spend $400+ on a set of RC 550's + $30 on a resistor pack (unless you custom order saturated which is extra $$) and $250 for an AFC which doesn't offer you the world of tunability a half decent standalone does. Your car, your call..
#1, he was not helpful, so **** off. Don't tell me to turn my sensitivity level down or talk down to me, that just pisses me off more. Smart ***! Is the AFC a piece of crap? Don't YOU use one yourself? Huh... maybe I should have said "I like to buy top notch components but I like having a crappy piggy back overall setup". Tell me the AFC is a useless piece of junk that doesn't do anybody any good..
#2, sure, if I could find a set RC had cleaned, fine. I have not seen any for $50 or whatever. I can't remember what RC charges to do it, but it's enough to motivate me to buy new injectors.
Damn, what's up with you guys today. When you say something, you have to know if it's insulting or irritating, so why would you expect a "oh nice, thank you"?
I asked a question. I did not ask for "that's not top notch afc sucks do it this way that's totally different from what you asked about" . Jesus, I gotta go now before I lose it.
BTW - I have a resistor pack already and 550 RC's can be had new for $269
[Modified by mplex2000, 10:22 PM 3/28/2002]
[Modified by mplex2000, 10:23 PM 3/28/2002]
You know what ... forget it. I don't want to fight with you guys no matter how irritated I get. This is the only board I like so why **** it up, right?
Sorry for having a TITTY ATTACK.
Dude you have got some serious issues or something.. I think you need to go chill and comeback later when you're cool and reread all the posts so you can see nobody is talking down to anybody, so I don't know why your telling me to **** off because all I've done is try to help you..
EDIT: Don't forget, Friday is just a few hours away.. maybe a few cold ones will loosen you up
[Modified by VTC_CiViC, 5:35 PM 3/28/2002]
we've tried the 550's and it doesn't work too well. also, after idle, getting on the throttle too hard just causes you to bog. i mean, it already can do that with 440's, but with the 550's, drivability(like going from 30% throttle to 100% throttle on the fly will cause flooding with the afc's. i got 360 to the wheels with 440's, so 300 won't be difficult. stay with 440's. just my opinion/experience.
but with the 550's, drivability(like going from 30% throttle to 100% throttle on the fly will cause flooding with the afc's..
As it is, I get a ton of that with the 440's, well I did before the AFC change but none the less, can you imagine what it'd be like on 550's!
I'm hoping dropping to 35psi idle pressure will help some of my funny idling though, get's annoying
i agree with VTC_CiViC, you need to calm the **** down.
i guess what i really meant was that your reason for not wanting DSM injectors is not a very good reason. Not wanting to use DSM injectors becuase they're not top notch, but yet at the same time going with a piggyback setup is hypocritical.
solution: use DSM injectors! There's nothing wrong with them! If you don't trust the injectors you buy, you can send them to RC and they will clean them and flow-test them for you for a small fee ($50-100 i believe).
-Xerxes
OK OK damnit I'm going to get the DSM injectors. It will be cheaper in the "right now" time frame and if I need the 550's I will get them later.
I should have been more clear when I made the original post - YOU CAN GET NEW RC 550 PEAK AND HOLD FOR $269 THRU THE LINK IN LSIVIC's SIG
I figured that's the deal of a lifetime, so I thought I would jump on it. Too much hassle though, so I will just save even more money and run the old DSM injectors for now.
Jinx - thanx for the good scoop!
PS - I already apologized so don't try to get me to say it again
Also, any good shops in the Tampa area? If all goes well I should be moving there in a couple of months!
[Modified by mplex2000, 11:25 PM 3/28/2002]
For reference, I emailed RC and they sent me this email.
"R.C. Engineering, Inc.
1728 Border Avenue
Torrance, CA 90501
(310) 320-2277 - Bus. #
(310) 782-1346 - Fax #
RCFuel@aol.com - e-mail http://www.RCEng.Com
Thank you for choosing R.C. Engineering. Regarding your previous
e-mail, you requested clean/balance/calibrating information. The cost to
clean/balance/calibrate your injectors are $24.00-$28.50/injector,
depending on the type of your injector. The turnaround time is delayed to 3
working days at this time due to very high volume of injectors to be
serviced. We apologize for the inconvenience. If you decide to send us your
injectors, please include the following:
~Name
~Address
~Year/Make/Model of car
~Telephone number/s
~For return shipping, UPS Nextday, TwoDay, Threeday Air, or Regular
Ground is available. The cost varies depending on the weight of the
package, your preference, and your shipping zipcode.
~For Payment, we accept MASTER,VISA,DISCOVER Card or COD/Money order.
We will contact you with the total when ready to be shipped. No personal
checks.
When the service is finished, we will be contacting you if we need any
additional information or will give you a grand total for the service.
If you have any questions, please contact one of our technicians at
your convenience.
Thank You,
R.C. Engineering"
You don't even have to tell them you're sending them. Just send info and the injectors. I'm going to get my DSMs done when I get them.
1728 Border Avenue
Torrance, CA 90501
~Name
~Address
~Telephone number/s
checks.
your convenience.
Thank You,
R.C. Engineering"
ive been noticing alot of people getting testy when they ask a question and dont get the answer they want to hear. at least some one answers your questions.....
