HOW to . . . Hondata clutch switch ?
Old Mar 5, 2003 | 10:33 AM
PM-Performance's Avatar
Default HOW to . . . Hondata clutch switch ?
I was wondering . . well one of these days befoe the track opens i wann hoko up the clutch switch , but how do you mount these things? anyone have pics or something ?i have yet to see one hooked up , but i want to use the functions of it
Old Mar 5, 2003 | 10:39 AM
sgT's Avatar
sgT
Default Re: HOW to . . . Hondata clutch switch ? (itr206)
i used the bolt where the cruise switch would normally go.
it threads right in its place.
Old Mar 5, 2003 | 10:53 AM
Default Re: HOW to . . . Hondata clutch switch ? (sgT)
cool , i guess i was confused with the switch i was thinking it goes behind the pedal?
like a reg 2step switch when it was depressed it would complete the circuit and hold the rpms where you needed until you let off the button .
now does this do the oppsoite kinda?
im just trying to maek sense how this works. . . does it funtion as a reg 2step or 3 step, , just opposite wiring per say?
maybe im making this more difficult than i should be ?
thanks though Steve. . . . . Just to let you knwo that base map you sent me , was like dead on almost in partial throttle and in boost was rich , but deff safe thnaks alot for your continuing help
Old Mar 5, 2003 | 10:57 AM
sgT's Avatar
sgT
we've done it both ways, thers another switch at the top thats for clutch interlock
and gets pressed when the clutch is on the floor. you can use taht one as well
but its rather hard to get to. I like to sidestep the clutch so having the switch in
the lower position works fine for me.
Old Mar 5, 2003 | 11:09 AM
so the one you use? . . . . is that the one thats like on the picture demo on hondata site? it mounts on top and depresses the switch when foot is off the clutch and lets the switch out when the clutch is depressed?
so it like breaks the circuit when the clutch is pressed in ? i see how that can work for the full throttle launch to lower the revs to make it less violent, but i dont understand hwo that situation works for 2 step purposes
if your foot is pushing the clutch down and your steady on the gas at the line . how does it know to engage the 1st limiter? thats where im getting stuck at ?, or is the cluctch switch only for the throttle shift and that pushbutton it comes with for the 2 step like a conventional launching control set up?
Old Mar 5, 2003 | 11:28 AM
sgT's Avatar
sgT
it monitors speed.
Old Mar 5, 2003 | 11:31 AM
so that really doesnt do anything for the launch control . . .(2step)?
Old Mar 5, 2003 | 11:46 AM
sgT's Avatar
sgT
when it reads speed as 0 it will engage the launch limiter, and while
at speed it engages the shift limiter and it still has overall rev limit.
Old Mar 5, 2003 | 11:51 AM
ohhhh ok , that makes more sence now .
thank you for clearing that up for me . i was ooking at it and going nutss.
Old Mar 5, 2003 | 04:53 PM
do people here diable the clutch switch on the streets ? doe sit affect driving becuase the way it works?i was reading that it drops rpms when the clutch is depresed?
Old Mar 5, 2003 | 08:03 PM
hybridsol's Avatar
Dude, once you drive with this installed, you'll NEVER go back... Hondata had a Quick Time movie of this at one time on their site.. have you seen it?
http://www.hondata.com/media.html
Old Mar 5, 2003 | 08:45 PM
LiLOtaku's Avatar
The easiest thing to do is solder/tap into the stock honda clutch switch. You can then find yourself a double throw/pull switch so you can disable/enable the switch with the hondata.
Old Mar 5, 2003 | 09:56 PM
2000GSRT's Avatar
Default Re: HOW to . . . Hondata clutch switch ? (hybridsol)
Here is the video:
http://www.hondata.com/media/fullthrottlefeet.mov
playahwitgame
Apr 19, 2006 10:37 AM
ham
Oct 5, 2005 02:46 PM
KoRE
Sep 15, 2003 07:28 PM
crx1856
Aug 22, 2003 11:48 AM
crx1856
Aug 5, 2003 11:35 PM
