How far can I push a fully built H22a????
I have a H22a4 head port an polished EVERYTHING in it is by Super Tech an black nitrate. The cams are from Bisimoto I have the leve 2.4 an Bisimoto cam gears. The block is a JDM H22A its sleeved stock bore size JE Pistos 9:1 compression Egale rods balanced an micro polished crank.... An EVERYTHING is for turbo... My goal is to make around 750-900+hp I was wondering if that was posible on my motor an the way it is built and what kind of turbo to use also how much psi could it handle...???? Im open to any quetions and advice
You're asking some basic questions and you're looking for 900hp? You're new to this? 900 may be more than you need lol. You can't do much more to a honda motor than you already have. Power is up to you and limited by fuel. PSI is based on power goal with a given turbo
precision sc6262 billet, throw 30 psi to it on race gas and be done with it. Its not gonna make those power goals. but it will still run you deep into the 10's with the kind of power it will make. No need for that much power unless your strictly drag racing...
scUba-stEve
Mar 26, 2005 07:23 PM
