hondata trouble, won't connect, did connect once before
crx, obd0-obd1 conversion, p28 ecu chipped by hondata, s200+boost+datalogging
turn ignition on, led on hondata solid red plug serial cable into laptop, solid red open hondalogger, led goes off, than back on won't connect, says connection error the chip isn't blank any thoughts? also , how can i tell if the ecu is damaged? engine light stays on, check the codes by grounded D4, and i get 2 flashes thanks |
Re: hondata trouble, won't connect, did connect once before (r7)
update, i believe i am getting a code 20 , and a code 41, i don't think those would have anything to do with hondata?
also, when i connect the serial cable to the laptop from the blue box, the led in the blue box starts to blink Modified by r7 at 12:48 AM 7/31/2003 |
Are you using a Dell laptop?
If you are, try gettinga USB to seiral adapter and us the UB instead of the direct serial connection. |
The Serial->USB adapter really helps. I always had problems connecting with my serial cable. After I bought the adapter my connecting problems *almost* all went way. Try connecting the serial before you switch the ignition on.
Re: hondata trouble, won't connect, did connect once before (Doodoo)
yeah, it's a dell laptop, i'll try the adapter
