Hondata question... what is shift limiter
Old Mar 30, 2003 | 07:10 AM
BoostedH23a1's Avatar
Default Hondata question... what is shift limiter
in the datalogging screen. under ecu there is an option for shift limiter.. what is that.. is that full throttle shift.. i set it to 6000 but when i full throttle shift it doesnt come down.. i only take my h23 to 6800 do i need to make it lower?
Old Mar 30, 2003 | 07:42 AM
Default Re: Hondata question... what is shift limiter (BoostedH23a1)
Old Mar 30, 2003 | 09:30 AM
ladysman's Avatar
Yes, shift limiter is the full throttle shift. I am not sure if you need to make it lower. It is probably fine at 6k
Have you got the push button to work for adjusting rev limits? I am 99% sure it doesn't work in the S200. So far the only luck I have had it adjusting it in Hondalogger.
Old Mar 30, 2003 | 10:19 AM
PM-Performance's Avatar
Default Re: Hondata question... what is shift limiter (ladysman)
i cant gfet that damn shift limiter to work right. no matter where i set it it kicks a rev limiter at 7500 or so without even doing the full throttle shift. im ripping it out soon ,.
Old Mar 30, 2003 | 10:57 AM
Spunkster's Avatar
Default Re: Hondata question... what is shift limiter (itr206)
I have no problems with them in my car.
Post exactly your setup, including ecu (the numbers on the actual board as well), s200 serial number, what clutch switch you are using, where it is mounted, etc.
Old Mar 31, 2003 | 08:37 AM
Default Re: Hondata question... what is shift limiter (Spunkster)
i have s200bd
running a obd 1 p72 ecu
the only thing i can adjust with the push button is my launch RPM.. everything else i have to do in hondalogger.
my rev limiter is at 6800 so i guess i cant use full throttle shift.
damnit. i thought it wasnt working....
Old Mar 31, 2003 | 08:38 AM
by the way its in my glove box and im using the stock clutch switch.
Old Mar 31, 2003 | 09:42 AM
Spunkster's Avatar
You cannot use the stock clutch switch, you must use the Hondata supplied switch. Also the serial number of you interface box would be helpful.
Old Mar 31, 2003 | 10:10 AM
oh...
how much are those i sold mine to a friend.. damnnit..
Old Mar 31, 2003 | 10:29 AM
JT's Avatar
JT
I think the main difference is one switch is N/C and one is N/O.
Old Mar 31, 2003 | 03:32 PM
Default Re: Hondata question... what is shift limiter (JT)
what
my launch limter works fine.. i flip on my switch (have it on a swich duhh) and bounce away at 2250
but no full throttle workage
Old Mar 31, 2003 | 07:41 PM
norcalcrx's Avatar
I am having the same problem. I am using the stock clutch switch with the hondata wires tapped in to it. My launch control works fine and i can set it to whatever rpm's, but i cant get the full throttle shift to work or setup. I have the s200 with boost and the 3 step. Using the p28 ecu. Thanks for any help.
Toby
Old Apr 1, 2003 | 04:41 AM
Default Re: Hondata question... what is shift limiter (norcalcrx)
yup same here... he said we have to use the supplied clutch swich.. i dont see why it would make a difference though.. on is on... off is off i would think
Old Apr 1, 2003 | 06:33 PM
norcalcrx's Avatar
Anyone have any advice for us?
Old Apr 2, 2003 | 04:57 AM
wonder how much that hondata clutch switch is
Old Apr 2, 2003 | 09:21 AM
Spunkster's Avatar
Call us at Hondata. Once we verify your serial number and that you have the 3-step option we an sell you a new switch.
(310) 782-8278
ACTION JACTION
Nov 7, 2008 09:37 PM
mike93eh2
Aug 30, 2007 08:17 PM
thrty8street
Jan 25, 2004 02:35 PM
lke2drvgsr
Dec 29, 2003 05:49 PM
turboex
Aug 29, 2002 08:48 AM
