Hondata Launch Control on street??????
Old Dec 7, 2003 | 06:21 AM
BoOsTiN Dc2's Avatar
Default Hondata Launch Control on street??????
I have a question about the hondata launch control... i already tried searching it up and couldnt really find anything covering this question... my question is when your launching when the hondata launch control at about 3500-400 rpm with full throttle on street tires, once you let go of your clutch you rev limit goes back to normal and your still on WOT won't you lose traction once you hit high rpm??? or do you launch and ease up on the gas so you wont lose traction?? i am running a LSvtec and gonna run about 10-12 lbs on the street with street tires... thanks in advance
Old Dec 7, 2003 | 07:30 AM
PM-Performance's Avatar
Default Re: Hondata Launch Control on street?????? (tRaCeBuStAbUsTeR)
2 steps are almost worthless on the street. i tried mine a few times and sat in a smoke bath
Old Dec 7, 2003 | 08:09 AM
Hondata's Avatar
Default Re: Hondata Launch Control on street?????? (itr206)
Then you need to lower your launch RPM to reduce wheelspin. That is the whole idea between having an adjustable the launch RPM.
Old Dec 7, 2003 | 08:34 AM
Default Re: Hondata Launch Control on street?????? (Hondata)
a full throttle launch on street tires is a fulthorttle launch. yes i can lower it to 2k RPM's and hope for traction . but trust me , they will still blaze up. its great for the track , but not optimal for street use unless you have like drag radials.
Old Dec 7, 2003 | 10:38 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">a full throttle launch on street tires is a fulthorttle launch. yes i can lower it to 2k RPM's and hope for traction . but trust me , they will still blaze up. its great for the track , but not optimal for street use unless you have like drag radials. </TD></TR></TABLE>
I have a switch to turn mine off for teh street.
Old Dec 7, 2003 | 10:48 AM
LiLOtaku's Avatar
Default Re: Hondata Launch Control on street?????? (ladysman)
ditto
I just grabbed a DPDT switch.
Endless Dynatsy
Sep 2, 2010 12:56 PM
acuralovar
Engine Management and Tuning
Nov 29, 2009 08:08 AM
spoonlongblock
Honda Civic (2006 - 2015)
18
Oct 20, 2006 06:41 AM
cpforyou
Aug 21, 2004 06:07 PM
ID_ten_T
Jun 17, 2003 08:37 PM
