hondata and injectors
In my Ls motor, I have a hondata 2b and what injectors do I need. I was thinkning 440's, but which ones? Also, do I need peak and hold, or saturated injectors. What is the difference. I plan on running no more than 10psi on stock internals.
[Modified by civcexcoupeblack, 10:11 PM 12/14/2002] |
Re: hondata and injectors (civcexcoupeblack)
Without a resistor box, you'll have to stick with saturated injectors. 440's are fine for your setup.
with 10psi I would rather use the safc with the aem fpr and 440cc sat injectors. But if you already have the hondata, then sat. injectors are the way I would go. Ez to install and no worries about having a used resister box that may not work right. RC injectors arent that expensive and will only be around 60 bucks more than the dsm and resister box.
Re: hondata and injectors (Dr.TurBo2006)
Would I need to upgrade my fuel pump also?
yes, intak pump will be fine.
| All times are GMT -8. The time now is 08:19 PM. |
